Insufficient data received error in modbus
paddy
Sep 11, 2012
81
I have a monitor which is programmed as modbus slave (RTU).
When I am connecting single device and checking the RS485 communication using Modbus poll and RS232 to RS 485 converter, it works fine. But when I connect another similar device in loop at that time it gives insufficient data byte error and CRC error.
For single device there is no problem but it gives error when I add another device. Please find attached text file.
Please advice what could be the problem.
Paddy
  • commdata.txt
paddy
Sep 11, 2012
81
The problem was occurring because of improper voltage (reverse voltage i.e. VCC is connected to GND and vice versa) to bias resistors.
Regards,
Paddy
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Thanks for following up here.
So that error meant that when a device stopped driving the RS-485 bus, it would be pulled into a break state? And that causes the Master to report "insufficient data" and a CRC error?
