integrated circuit modeling with LTSpice
  • Thread starter Michael Robinson
  • Start date
Michael Robinson
I'm in the unfortunate position of having to use LTSpice to work on a CMOS
circuit design. If you must know why, our school's Cadence installation has
bugs.
So far I've figured out I can make a level 1 model that successfully shows
body effect. I'm working on the parasitics. I can put in a values for Cbd
and Cbs; to get Cgs and Cgd I have to put in Cgso Cgdo and specify the gate
dimensions, and so on. I read about Cgdmax and Cgdmin, so I tried them but
haven't been able to get LTSpice recognize them yet.
Sometimes the simulator does odd things. In one case the simulation time I
specify affects the results; for example, there's a current source circuit
that goes unstable when simulated for 10 microseconds, but when simulated
for 10 milliseconds, is stable.
This project is a CMOS integrated circuit current source subjected to hard
switching. Step response is the big thing. I'm going to be making bode
plots of the frequency response to analyze the stability, so I want to get
the parasitics right. Some values I'm still not sure of are Is, Rg, Rd, Rs,
Rb. I've been looking through Chapter 2 of Gray's "Analysis and Design of
Analog Integrated Circuits." It's a great reference but working through
this stuff has consumed entire days that I don't have to spare. If Cadence
was working, I could just fire up virtuoso, plunk some mosfets down and run
the circuit. So I'm looking for some way to do this quicker and better.
Are there ready-made resources for using LTSpice in CMOS modeling?
Michael Robinson
circuit design.
[snip]
Level=1 is crap. Why aren't you using a BSIM model?
Since you have the Cadence tool set, can't you read the device model
library? LTspice _does_ recognize BSIM3xx models.
You might post an LTspice schematic so that we know what you are
trying to do.
...Jim Thompson
All right thanks, now I'm getting some information I can actually use.
In outline, my project is to improve the speed of a charge pump that one of
our professors patented some years ago.
You can see the patent if you go to google patents and type in 7583116.
Here is a LTSpice netlist I threw together for his charge pump circuit's
topology. Mine will be a bit different, but I'm posting the original. As I
recall, after putting in the "miller" cap to stabilize it, the original
circuit ran (switched) at 100 MHz. Because I've only been able to come up
with a very crappy model for the mosfets so far, I had to use much slower
switching in the simulation.
I'm attaching an LTSpice netlist for the basic topology of the circuit in
the patent below if for some reason anyone wants to play with it.
All the nmos are identical. I have one pair of mosfets doubled up, where in
the original patent you'll see a single mosfet with twice the aspect ratio
of the others. I also don't include a high-side current source, which is
essentially a mirror image of the one you see.
Version 4
SHEET 1 1788 680
WIRE 352 -256 256 -256
WIRE 368 -256 352 -256
WIRE 560 -256 368 -256
WIRE 576 -256 560 -256
WIRE 768 -256 576 -256
WIRE 784 -256 768 -256
WIRE 976 -256 784 -256
WIRE 1184 -256 976 -256
WIRE 1200 -256 1184 -256
WIRE 688 -192 496 -192
WIRE 1104 -192 688 -192
WIRE 368 -176 368 -256
WIRE 560 -176 560 -256
WIRE 432 -160 416 -160
WIRE 496 -160 496 -192
WIRE 496 -160 432 -160
WIRE 512 -160 496 -160
WIRE 768 -160 768 -256
WIRE 1184 -160 1184 -256
WIRE 688 -144 688 -192
WIRE 720 -144 688 -144
WIRE 1104 -144 1104 -192
WIRE 1136 -144 1104 -144
WIRE 352 -128 352 -256
WIRE 368 -128 352 -128
WIRE 576 -128 576 -256
WIRE 576 -128 560 -128
WIRE 784 -112 784 -256
WIRE 784 -112 768 -112
WIRE 1200 -112 1200 -256
WIRE 1200 -112 1184 -112
WIRE 432 -80 432 -160
WIRE 432 -80 368 -80
WIRE 976 -48 976 -256
WIRE 368 -32 368 -80
WIRE 368 -32 288 -32
WIRE 368 -16 368 -32
WIRE 976 0 912 0
WIRE 1120 32 1024 32
WIRE 1184 32 1184 -64
WIRE 1184 32 1120 32
WIRE 288 64 288 -32
WIRE 320 64 288 64
WIRE 976 80 976 48
WIRE 992 128 976 128
WIRE 1184 128 1184 32
WIRE 928 160 -64 160
WIRE 1200 176 1184 176
WIRE 256 208 256 -256
WIRE 560 208 560 -80
WIRE 624 208 560 208
WIRE 768 208 768 -64
WIRE 1136 208 768 208
WIRE 560 224 560 208
WIRE 768 224 768 208
WIRE -64 272 -64 160
WIRE 560 272 544 272
WIRE 784 272 768 272
WIRE 624 304 624 208
WIRE 624 304 608 304
WIRE 720 304 624 304
WIRE 368 320 368 80
WIRE 368 320 320 320
WIRE 368 352 368 320
WIRE 560 352 560 320
WIRE 768 352 768 320
WIRE 976 352 976 176
WIRE 976 352 768 352
WIRE 128 384 0 384
WIRE 384 400 368 400
WIRE 544 400 544 272
WIRE 560 400 544 400
WIRE 784 400 784 272
WIRE 784 400 768 400
WIRE 992 400 992 128
WIRE 992 400 976 400
WIRE 1120 400 1120 32
WIRE 320 432 320 320
WIRE 624 432 624 304
WIRE 624 432 608 432
WIRE 720 432 624 432
WIRE 1152 448 1120 448
WIRE 720 464 720 432
WIRE 928 464 928 432
WIRE 928 464 720 464
WIRE 128 480 128 384
WIRE 1072 480 128 480
WIRE -64 512 -64 352
WIRE 0 512 0 464
WIRE 0 512 -64 512
WIRE 256 512 256 288
WIRE 256 512 0 512
WIRE 304 512 256 512
WIRE 368 512 368 448
WIRE 368 512 304 512
WIRE 384 512 384 400
WIRE 384 512 368 512
WIRE 544 512 544 400
WIRE 544 512 384 512
WIRE 560 512 560 448
WIRE 560 512 544 512
WIRE 768 512 768 448
WIRE 768 512 560 512
WIRE 784 512 784 400
WIRE 784 512 768 512
WIRE 912 512 912 0
WIRE 912 512 784 512
WIRE 976 512 976 448
WIRE 976 512 912 512
WIRE 992 512 992 400
WIRE 992 512 976 512
WIRE 1120 512 1120 496
WIRE 1120 512 992 512
WIRE 1152 512 1152 448
WIRE 1152 512 1120 512
WIRE 1184 512 1184 224
WIRE 1184 512 1152 512
WIRE 1200 512 1200 176
WIRE 1200 512 1184 512
FLAG 304 512 0
SYMBOL pmos4 416 -80 R180
SYMATTR InstName M1
SYMBOL nmos4 608 224 M0
SYMATTR InstName M2
SYMBOL voltage 256 192 R0
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName V1
SYMATTR Value 1
SYMBOL nmos4 608 352 M0
SYMATTR InstName M3
SYMBOL pmos4 512 -80 M180
SYMATTR InstName M4
SYMBOL nmos4 320 352 R0
SYMATTR InstName M5
SYMBOL nmos4 720 224 R0
SYMATTR InstName M6
SYMBOL nmos4 720 352 R0
SYMATTR InstName M7
SYMBOL nmos4 928 352 R0
SYMATTR InstName M9
SYMBOL pmos4 720 -64 M180
SYMATTR InstName M10
SYMBOL nmos4 1136 128 R0
SYMATTR InstName M11
SYMBOL pmos4 1136 -64 M180
SYMATTR InstName M13
SYMBOL nmos4 1024 -48 M0
SYMATTR InstName M14
SYMBOL voltage -64 256 R0
SYMATTR InstName V2
SYMATTR Value PULSE(0 1 0 10n 10n 1u 2u)
SYMBOL nmos4 1072 400 R0
SYMATTR InstName M12
SYMBOL nmos4 928 80 R0
SYMATTR InstName M15
SYMBOL voltage 0 368 R0
SYMATTR InstName V3
SYMATTR Value PULSE(1 0 0 10n 10n 1u 2u)
SYMBOL nmos4 320 -16 R0
SYMATTR InstName M8
Michael Robinson
Jim Thompson said:
in
message news:[email protected]...
On Wed, 4 Apr 2012 00:51:36 -0400, "Michael Robinson"
CMOS
circuit design.
[snip]
trying to do.
...Jim Thompson
of
I
in
[snip]
(1) I see no dimensions on the MOS devices.
I had spice directives on the schematic. I didn't think they would be much
use so I deleted them before I posted the netlist. But here they are
..model PMOS PMOS(Level=1 Gamma=.2673 Tox=8n Phi=.33 Rs=.01 Kp=.065 Vto=-0.4
Lambda=.05 Rd=.01 Cbd=.009p Cbs=.027p Pb=0.7 Is=10f N=1)
..model NMOS NMOS(Level=1 Gamma=.0945 Tox=8n Phi=.385 Rs=.01 Kp=.15 Vto=0.3
(2) What process? I have models from many foundries. Maybe I have
the one you need.
It was a process IBM was using in the nineties, but I don't have to use the
original process. I just want something that works.
(3) Or send me the models from your Cadence libraries.
...Jim Thompson
I'd like to send you more information, but I couldn't get through the email
icon on your website. Is there any way I can send you email from my school
account?
It is mrobins2 at uvm.edu
miso
It is my understanding that during transient analysis, the smallest
step size is proportional to how long you look, like 1/200th. Unless
something really interesting happens, then the steps will get
shorter. But, DON'T get shorter UNLESS something interesting
happens.
For example 0 to 1 sec has fairly large steps compared to 0 to 10 uS,
which means the analyses probably 'stepped' over your circuit's
instability.
You can confirm this by adding to your transient command largest step
is 1nS and see what happens.
You are correct. Spice picks the time and then curve fits the output to
fit on your time grid unless you make the effort to specify the time
step. For circuit analysis where timing is critical, you need the max
time step parameter. This also effects THD calculations.
F
Fred Abse
Vto=-0.4 Lambda=.05 Rd=.01 Cbd=.009p Cbs=.027p Pb=0.7 Is=10f N=1)
The LTSpice symbol you used needs dimensions, not a .model. Try right
clicking on each symbol to see what I mean.
Michael Robinson
I can put dimensions in that dialog box, in fact I tried doing it that way,
but then the circuit had infinite bandwidth. Perfect step response up in
the terahertz or something.
No way around using a model for the parasitics. And of course there's also
body effect.
F
Fred Abse
way, but then the circuit had infinite bandwidth. Perfect step response
up in the terahertz or something.
also body effect.
The three-terminal NMOS symbol takes a .model. Alternatively you could
(like I did) make a new "subckt NMOS" symbol that is really an "X", and
takes a subcircuit that you provide. A lot of manufacturers devices have
subcircuit models, I originally did it to replicate Jim's 2N7000 model
comparisons of eons ago.
