Integrated Circuit with PNP and NPN transistor as bypass gate
hpfiend
Feb 20, 2013
31
Ok guys/gals-
I need some help with the lingo. In my mind it would be called a bypass gate but that isn't looking to be the case. What would an IC with a PNP and NPN transistor with shared Bases be called?
Basically the main current travels path A until the switch current is applied to base of both transistors. The NPN switches on to open path B through the circuit and simultaneously the PNP switches off to close the path A.
Thanks!
GreenGiant
Feb 9, 2012
842
Sounds like you are describing a SPDT transistor gate of some sort, Im not sure if that exists in a single IC, but you can always use 2 transistors for it, one PNP, one NPN
hpfiend
Feb 20, 2013
31
Yeah that is what I was going to do but thought it might already be built in one chip. I will search single pole double throw transistor gate.
Thanks!
hpfiend
Feb 20, 2013
31
Thanks for your response!
Other than packaging and mechanical reliability would a SPDT relay be a better solution here to avoid the voltage drop through the transistors?
It depends entirely on your application.
I'm also thinking that the device might be a bipolar half-bridge.
You can easily get 2 transistors in a single package.
