interface real world to pc question?
russ
Hi
Any help on this would be appreciated.
I want to read in an analogue voltage from the 'world' into my
computer, process and store it at regular intervals. I want to do
this via the serial port. I therefore need an 'interface' where my
voltage is an input and the output feeds into my serial port. The
interface and my pc then interact via some C code or something. Does
anybody recommend any very cheap 'interface' which would do this?
There are obviously very expensive 'data acquisition cards' on the
market, but my needs seem very simple in comparison.
Thanks in advance
Russ
Jonathan Kirwan
Obvious questions will include:
What is the range of your input voltage?
Does it need to be isolated from the PC?
How fast will the sampling be?
How much precision is required?
Single-ended or differential?
How is the signal conveyed?
What kind of loading can be tolerated by the driving circuit?
What accuracy is required?
What kind of powering for the 'interface' is desired?
There is an example of one possible circuit at:
http://www.elecdesign.com/Files/29/1447/Figure_01.gif
from this article:
http://www.elecdesign.com/Articles/Index.cfm?AD=1&ArticleID=1447
That example powers itself from the serial port pins.
Jon
Bob Masta
Hi
If you really want to use the serial port, and you are
running Windows, there is an inexpensive board from
Dataq for $US 25. If the current model is like the
older ones, they are 4-channel units that sample at
a few hundred Hertz max. Comes with software for
a chart recorder.
There are also pricier products from a number of
suppliers, which you could probably locate by Googling
on "Serial port" and "analog input" or "data acquisition"
or some such.
If you are running DOS and don't mind using the parallel
port instead, you can make a simple 8-bit A/D from
nothing more than a handful of resistors. It uses the
"successive approximation" method, just like in "real"
A/D converters. The LPTX driver for my Daqarta
package uses such a design, which you can find
at
www.daqarta.com/lptx.htm
Look for the SAR (Successive Approximation Register)
model.
Hope this helps!
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Chris
russ said:
Hi
Thanks in advance
Russ
Hi, Russ. You've already gotten some good advice from other posts.
However, if you're looking for something Q&D that'll do the job with
absolute minimum fuss at moderate cost, and you can live with fairly
slow readings (seconds apart instead of milliseconds/microseconds), you
might want to look at the Radio Shack PC Interface 46-Range Digital
Multimeter Catalog# 22-812 for $69.99 USD. You get an adequate
multimeter and software which will allow you to do datalogging without
programming just by hooking up the included cable from the DMM to your
serial port and running the program. This will give you the capability
to read analog DC and AC voltages and currents as well as resistance,
and temperature with an RTD or optional Extech temperature adapter
module Catalog# 910-5611 (an additional $39.99 USD).
Good luck, and have fun
Chris
Lawrence Oravetz
Jonathan Kirwan was thinking very hard :
from this article:
Jon
Something else to consider.. a volt meter that has a serial interface
built in. There are many available from Radio Shack to Fluke.
Hello to anyone who cares about this Radio Shack Digital Multimeter
cat# 220-0812. I wrote an interface for myself, that I'd like to share
with you. The requirements are unix and a copy of gambas, and you get
the full source code.
Note that, I found, that, for whatever reason, the instrument sends
wrong checksums every once in a while - you can see the number of
resets. I know it's the instrument's or serial connection's fault,
because when displaying 0.F MOhms overrange continuously, I know
nothing changes, yet the correct 9A checksum from the device changes to
12 and 0, and other values, about every dozen 9-byte packet. This also
messes up the byte-order. Doing a port reset, disconnect reconnect
resyncs things. When there is a real resistance measured there are
almost no resets. Another sensitive knob position with lots of resets
over checksum errors is the temperature-mV one, when values widely
fluctuate. Still, with a capability of 3 readings per second, you can
just ignore any off-values and keep the rest, the device still
functions very well, for the price. You can guess some costs were
saved. Instead of summing checksum, they could have provided a CRC8,
and made the packet 10-byte with an STX,ETX or LF char signifying end
or beginning of packet, so there is never an issue trying to figure out
which is the starting byte, and there would be no need for resets. Also
some hardware handshake option would have been nice, because DTR/DSR
and RTS/CTS are just dummy looped back to each other. But still a fun
little device, and excellent cost, considering it's from a
brick-store-in-your-neighbourhood retailer.
Grab the program at
http://home.earthlink.net/~sztakacs/gambas-RadioShackDMM.tar.bz2 and
you may view a screenshot (377KB png image) at
http://home.earthlink.net/~sztakacs/gambas-radioshackdmm.png
Jamie
Grab the program at
maybe you have your parity set incorrectly ?
