Is it okay if I leave an opamp or comparator input open?
MRW
I am curious if it is okay to leave an opamp or comparator inverting
or non-inverting input open while the device is powered.
Thanks!
DJ Delorie
Op amps have such a high gain that leaving an input open will probably
drive the output into saturation, which isn't ideal. Better to
configure unused op amps as unity-gain (tie in- to out) and use a pair
of resistors to set the input voltage to half the supply voltage.
That keeps all the pins in spec and happy.
MRW
Okay. I think I get it. Thanks! Hmm.. I do remember reading somewhere
that the opamp input terminal has to have a path back to ground to
make it happy.. or something like that. I don't quite remember, but I
guess that would make sense if we tie the inputs to a voltage source
or ground.
Would a circuit like this work?
GND
V
| GND
VIN2 -- ----|-\
| >-VO
VIN3-|+/
VCC
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
VIN3 in the diagram is a fixed voltage source, while VIN2 is either
there or not (like plugged in or plugged out). Thanks!
Eeyore
It probably won't damage it but it certainly won't work in any meaningful way.
Graham
John Larkin
or ground.
GND
V
| GND
VIN2 -- ----|-\
| >-VO
VIN3-|+/
VCC
Some opamps will draw a lot of supply power if their outputs rail, as
they will if they are not operating closed-loop. And in some dual or
quad-section opamps, running one section open-loop will mess up other
sections. In general, keep all opamps running closed-loop, like this:
| GND |
| >-----+----VO
VIN3-|+/
VCC
or
vin2---+------1M------+
| GND |
| >-----+----VO
VIN3-|+/
VCC
or some other way to keep it happy when your input is disconnected.
John
MRW
meaningful way.
Graham
Thanks, Graham! I'd like to make it work in a meaningful way and not
damage it. I think I understand now.
MRW
John said:
probably >> drive the output into saturation, which isn't ideal.
Better to >> configure unused op amps as unity-gain (tie in- to out)
and use a pair >> of resistors to set the input voltage to half the
supply voltage. >> That keeps all the pins in spec and happy.
John
Thanks, John!
Manoj
Thanks, John!
--- Hide quoted text -
- Show quoted text -
dear freinds,
there are many application notes to this effect from almost all big
manufacturers.
i think comparator pins can be left open, coz they are one way or the
other in saturation.
saturation state for op-amp is not good, one coz they take a lot of
current and second it will put in a lot of noise on the supplies.
the best idea is to keep op-amp in a known state and for that u should
tie both minus and positive pins such that u ahve a output close to
mid point of supply voltages applied. do read application notes of
national for this application.
with regards
manoj
