is this fast enough to catch the motherboard frequency???
mc
wefixpc said:
It says it goes up to 5 MHz on digital signals. So it will measure the CPU
clock of a 1981-model IBM Personal Computer. Today's fast PCs are about
2500 MHz (2.5 GHz).
A further problem is that as I understand it, in today's fast CPUs, the
high-frequency clock signal exists only inside the CPU chip. It is
multiplied from a lower-frequency signal outside. Am I remembering
correctly?
Ray L. Volts
CPU clock of a 1981-model IBM Personal Computer. Today's fast PCs are
about 2500 MHz (2.5 GHz).
correctly?
Yep, internal clock frequency isn't the same as the bus frequency from the
cpu to the outside world. You're a little behind the times at 2.5GHz,
however. The latest desktop Pentium 4, for example, has a 3.8GHz clock.
