Is this float switch circuit really all I need?
MarkMc
I need to turn on a solenoid valve to let water in to a container
whilst a float switch is down (n/c configuration).
I was just going to put the switch and the solenoid in series with a
240v AC supply.
Is this really all I need or is this rather naive?
Regards,
Mark
John Fields
240v AC supply.
If the current and voltage rating of the switch is >= the voltage
and current rating of the solenoid then that's all you should need.
If it isn't, then you'll need to use the switch to drive a relay and
the relay (in series between the mains and the solenoid) to drive
the solenoid.
Jasen Betts
240v AC supply.
That is almost exactly how washing machines fill to the apropriate
level. (except they use a pilot tube pressure sensor)
Bye.
Jasen
