Isolated variable resistor function?
Joerg
Hi Folks,
Does anyone know a part that is small, can be used to command a certain
resistance and can be talked to across the usual mains-isolated barrier
of office equipment and the like? I need to set resistor values on the
mains side from a uC on the low voltage side. Has to be:
Linearity error from 0V to about 1V excitation should be <5%.
Absolute resistance tolerance <20% if possible.
Bandwidth for resistor value changes up to a few kHz.
No limit on the number of changes (meaning no EEPROM).
Addressable across isolation barrier.
So far I've considered:
a. FET optocouplers such as the H11F1. A bit pricey at over $1 but most
of all has the problem that the linearity goes to pots as soon as there
is more than 20-30mV across the FET, plus it needs a ton of drive power
for low resistance:
http://www.fairchildsemi.com/ds/H1/H11F1M.pdf
b. Digital potmeters such as the MCP4011 series. These are nice, tons of
bandwidth, cheap and small. But they do need an additional two-channel
optocoupler to get the command data across and the absolute resistance
value tolerance is borderline at 20%:
http://ww1.microchip.com/downloads/en/DeviceDoc/21978c.pdf
c. Servoed FET plus opto. The servo gets rid of the non-linearity. Done
it before but this gets old because it needs a lot of parts and real estate.
d. LDR plus LED: Very nice, but fairly large and most of all LDRs are
banned in some countries on account of their Cadmium content.
Any other miracle parts out there?
Hi Folks,
for low resistance:
Does it have to be four-quadrant? Floating? There are some cute fake resistor
circuits around but the ones I've tried using need one end of the pot at
"ground". That and an isolated DAC (DAC on the far side of an isolator, even)
will solve your tolerance problem. You probably won't like the cost, though.
Joerg
John said:
Any chance you can PWM a resistor?
Would be nice but the part where the resulting signal goes into is
blazingly fast (has to be). So the PWM would cause an undesired modulation.
But it is an idea, maybe I can slow something down in there. And go in
with several meggeehoitzes. The uC we have would moan and groan though.
Joerg
Actually single quadrant is ok and one side of it can be grounded. Cost
is a factor but not like in most of my other design. Meaning a buck is
acceptable but two bucks would be a stretch.
Joerg
Jan said:
PIC with ADC on one end with RS232 out one opto
PIC on other end with PWM DAC out (assuming you need some control voltage).
You really live your PICs :)
I don't need a control voltage but a control resistance. That's the
challenge. Getting a voltage across is way easier: You'd just send PWM
out of the uC that we already have, onto an optocoupler, and then
RC-filter this into a DC voltage one the other side. Could be done for
<30c. Of course they'll throw coffee mugs and paper wads at me because I
would have to file a request for the 2nd timer in there. Analog guys
always want the timers. Well, those plus beer and marzipan.
How good of a resistor do you need? Is an opamp fast enough?
Joerg
Yes, it is fast enough. But it has to behave like a real resistor, up to
several kHz.
Joerg
Jan said:
OK, very long plastic rod with potmeter.
That would require shipping a trained mouse with every unit. Too
expensive because of the food, veterinary bills and so on.
Jon Kirwan
Some of the MSP430's have Timer D, which will run PWM at
256MHz -- if I read correctly.
Jon
Jon Kirwan
<snip>
I should have said "clocked at 256MHz," but you already know
that the count per period would divide this down for the PWM
frequency. Sorry about not being precise in writing that.
Jon
Joerg
Jan said:
I have made very nice 'resistors' with MOSFET with feedback resistor network to gate.
So have I, but tough to achieve a sustained 5% linearity over production
runs. I've done it in servo fashion but with all that you quickly reach
a point where a 30-40c digital potmeter is simply the better solution.
Joerg
Jan said:
No no, it saves a micro.
This assumes that the equipment is used by a human.
Why the electronics?
he / she can twiddle the pot directly.
The uC has to do the twiddling.
Joerg
A MSP430 clocked at 256MHz? Shazam! That sounds like a Suzuki Alto with
a Hayabusa engine in there.
Why is linearity an issue (feedback, ya' know)? Drive it with a good (5%
isn't "good") multiplying DAC.
Joerg
Why is linearity an issue (feedback, ya' know)? ...
The signal going into this divider can't be distorted more than 5% and
with a FET-optocoupler it would be.
... Drive it with a good (5% isn't "good") multiplying DAC.
Sure, but then I might as well just use my solution "b", a digital
potmeter. Reduces that function to one part costing 30-40c, outside the
optocoupler to xfer the data lines which I'd need either way.
Jon Kirwan
Hehe. I was just needing a faster PWM (wanted to use a very
cheap RC, 20db/decade rolloff, low-pass, but needed an audio
spectrum. Couldn't get there with 1/62500 PWM period of
standard MSP430. So I looked and... cripes!! They had
something else!
"Timer D also includes a dual capture mode reducing loading
of capture operation by half. In addition, the combining
compare blocks help to control both rising and falling edges
of the PWMoutput signal. The Timer-Event-Control-block offers
external triggering options as well as internal
synchronization of timer instances."
See the MSP430F51x2 parts.
http://www.ti.com/product/msp430f5172&DCMP=msp430&HQS=430timer
Jon
Joerg
Jim said:
John Larkin wrote: [snip]
Please define "blazingly fast"?
In this case several MHz. In the world of switch mode power supplies
that counts as "blazingly fast" :)
