Jaycar Speed corrector in Ford AU
Davo
Uncle said:
Hi all,
I've got an Ford AU3 Fairmont that has aftermarket rims/tyres.
This throws the speedo out by about 10%.
I am trying to sort out whether a Jaycar speed corrector
(http://tinyurl.com/dblvbw) will sort out the speedo error without
incurring other issues.
Other issues may be shift points for the auto transmission and/or
problems with cruise control.
I've hunted around the net looking for answers and came across a post
where someone suggests that to control shift points it may require TWO
speedo correctors.
First corrector to drop the signal from the auto transmission to the
speedo and the second corrector to increase the signal from the speedo
to the ecu.
Can any of you electronic boffins shed some light on this for me.
I'm competent to assemble and install the kit but when it come to
understanding electronics I'm lost.
Thanks for reading.
What about putting the correct size tyres on?
atec 7 7
crazyclark said:
Sure, that's always an option but given that the rims and tyres fall
within the legal size for my car, it's good to individualise a little...
Got a clue with regard to the question?
Swap the gearbox sender to one which suites is much better.
U
Uncle Al
Hi all,
speedo correctors.
to the ecu.
Thanks for reading.
atec 7 7
mark said:
That's interesting, thanks for that.
In the past I've changed speedo gears in manuals but wasn't aware that a
similar (if different) proposition was possible with auto's.
i assume it's much the same with drive running through an adaptor
Can you elaborate a little as to where I'd chase it up and what I'd ask
for when I get there?
Well ask ford first , I have used after-market from the valley in
Brisbane
(Is it simply a matter of saying that my speedo reads 10% high and could
I have a speedo sender to suit, or is there more to it?)
I supplied the required information and he came back with the righ
adaptor
crazyclark
mark brothers uncle
Mr.T
Probably cheaper and far more accurate to just use a GPS unit for speed
readout. And if your speedo reads 10% high, your just less likely to get
booked anyway!
(are you sure it's reading high though? IF your tyres are bigger
circumference it will read low. If they are lower profile and the same
width, then they would be smaller circumference and you would be correct of
course. IF they are both lower profile and wider, as is often the case with
aftermarket "upgrades", then the circumference is usually not 10% different)
And the speedo reading has *ZERO* affect on your cruise control BTW. Are you
really incapable of adding/subtracting 10% to the indicated speed when you
set it?
MrT.
F
Franc Zabkar
Hi all,
speedo correctors.
to the ecu.
Isn't the sensor a 3-wire Hall Effect type, in which case the signal
would be in digital form? Wouldn't it be wired directly to the ECU?
If the "someone" above is suggesting that the ECU should continue to
see the actual speed of rotation of the transmission, regardless of
road speed, then you would only need to connect the speedo corrector
between the ECU speed output and the speedometer input, assuming the
output is a pulse type.
This could be the kit -- Super Speedo Corrector:
http://www.jaycar.com.au/products_uploaded/productLarge_9901.jpg
http://www.siliconchip.com.au/cms/A_108157/article.html
http://us1.webpublications.com.au/static/images/articles/i1081/108157_3mg.jpg
http://us1.webpublications.com.au/static/images/articles/i1081/108157_4mg.jpg
http://us1.webpublications.com.au/static/images/articles/i1081/108157_5mg.jpg
http://us1.webpublications.com.au/static/images/articles/i1081/108157_6mg.jpg
http://us1.webpublications.com.au/static/images/articles/i1081/108157_7mg.jpg
- Franc Zabkar
F
Franc Zabkar
If your car has an option for a lower ratio differential, then you
could get the speedo sender that was designed to match it. IIRC,
common ratios for other makes (in the 70s) were 2.92, 3.23, 3.50.
These differ by about 10%.
Doing this, however, may change the shift points for your automatic
transmission.
- Franc Zabkar
gets tedious don't it
Well ask ford first , I have used after-market from the valley in Brisbane
I supplied the required information and he came back with the righ adaptor
Thanks mate, appreciate your input.
I rem your nic from the old a2600w days - glad to see you're still
contributing :)
suss it out
booked anyway!
set it?
MrT.
Well... a bunch of assumptions based on what?
If I only had one set of aftermarket rims in one size with one tyre
profile and only drove it to the local shops then I may run with your
line of thinking. That ain't the case.
Obviously a closer reading of my op would clue you in that I wasn't
suggesting that the speedo reading *did* have any effect on the cruise
control.
I don't know why whether or not I'd prefer my speedo to be accurate is
worth you commenting about stuff of which you've no idea (my situation;
my preferences; whether I have a gps; whether I have a clue about tyre
sizes and speed differentials; at what speed I'm indicating a 10%
difference; whether my calculating skills are adequate etc etc) but I
guess if you've got time on your hands...
Got any input about Jaycar speedo correctors?
