Joining transformer wirer
gregrae
Jan 12, 2011
67
I am winding a coil and need to join another length of enamel wirer to the previous enamel wirer to continue winding.
What is the best way to join the wirer together .
I know there is several methods but I would like to get other opinion for this job.
Burn off insulation from both ends to be joined and/or scrape clean, wrap together and solder or crimp and insulate.
Not a good idea though to join in any case, especially for any high voltage component.
Bound to break down in the future causing shorted turns.
14,487
what sort of coil ?
what wire size ?
what voltages/current ?
show us a photo
gregrae
Jan 12, 2011
67
Voltage 240v DC
Current 8 amp
20 gauge
My recommendation is to start with a longer piece of wire.
For a whole lot of reasons, joins in the wire are a bad thing.
Colin Mitchell
Aug 31, 2014
1,416
The only way is to bring it out as a tap, even if you are not going to use it as a tap.
Obviously none of the others have ever wound a transformer.
Good point Colin. (edit: the first one, not the second)
I have, but it was a long time back and early in the morning here when I replied........:):)
GPG
Sep 18, 2015
452
240 x 8 =1.92 Kw. Be a nice heater.
14,487
uh huh
I suspect the OP has more than the AC/DC error in the info he has listed
none of it really makes sense
duke37
Jan 9, 2011
5,364
To keep the power to a minimum, the space should be filled, you can either use thin wire, lots of turns and lots of volts or thick wire, few turns and few volts. The ampere turns should be the same.
Making the device longer will not affect the necessary number of turns or the current, it will however affect the voltage which will be proportional to length.
gregrae
Jan 12, 2011
67
Having done a lot of research and number crunching The arcing of switches would be very high.
I will use a microwave transformer as a Isolation transformer an use the interlocks and temperature sensors .and controleis to operate the electro magnetic bender to eliminate arcing and there is no reference to earth.The same as whe do with a live chasey TV using a isolation transformer .
What is your opinion.
duke37
Jan 9, 2011
5,364
There must be a high standard of insulation of the coil from the pole piece.
The pole piece should be grounded (earthed).
Thre should be no difficulty with arcing if the DC is provided with a bridge rectifier placed across the coil. This will act as a flywheel diode, so switch the AC input to the bridge.
