Just When I Thought it was Going to Be Easy
SparkyCal
Mar 11, 2020
863
As many of you know, I successfully built an overdrive pedal using the 4558D double op amp IC, with the help of the kind folks here.
My journey can be found on this thread: https://www.electronicspoint.com/forums/threads/back-to-the-breadboard.295296/
The schematics I used can be found here:
https://www.electronicspoint.com/forums/threads/back-to-the-breadboard.295296/page-4
and here:
https://www.wamplerpedals.com/blog/...ow-to-design-a-basic-overdrive-pedal-circuit/
So, I thought, since I built this successfully with a dual op amp, why not try it with a single op amp.
I have a ton of the TL081CP op amps, which are single op amps. Datasheet here:
https://www.ti.com/lit/ds/symlink/tl082h.pdf?ts=1627155765274&ref_url=https%3A%2F%2Fwww.google.com%2F
So, I build the entire circuit, and the last part was to insert the op amp into the socket. I did so, but because my eyesight sucks, I accidentally put it in upside down. I only mention this because I am not sure if it caused the problem I am about to describe.
I took the op amp out of the socket and threw it out. I inserted a new one, this time, correctly.
However, I am getting the following Pin readings- and yes, I did remap the pins according to the pin mappings for a TL081CP op amps:
These readings are in Volts:
Pin1. 7.6
Pin2. 4.0 and counting down
Pin3. 4.5
Pin4. 0
Pin5. 1.1
Pin6. 4.4
Pin7. 9.02
Pin8. 8.17
I don't think these readings make sense. Could I have fried some components when I inserted the op amp into the socket the wrong way?
Thank-you
UPDATE: Forget it for now. I think I may have screwed up my wiring. I will update o once I sort this out.
VenomBallistics
Aug 30, 2018
285
the TL 082 was my go to op amp for this sort of thing back in the day.
Speced out similarly to the 072, trading off very little for some cost savings ... Mild bonus when you anticipate silicon to carbon conversion at every turn.
every migration seemed to be graced by what you describe ... user error and pinout confusion.
you have to embrace the sweet release of the magic smoke
VenomBallistics
Aug 30, 2018
285
Well, that's a fair fist full of action really.
I'm sure you have a rough understanding of how things function, particularly how the gain pot alters the ratio between it and the bias resistor to control the amount of distortion.
With a parts mine like what you have there, you might try amending the NFB loop with a jfet connected to an envelope follower so the distortion can be controlled by pick attack.
It might mimic tube amp dynamic behavior.
Audioguru
Sep 24, 2016
3,656
Input pin 2 is supposed to have the same voltage as the output pin 6 which feeds the voltage to it through the gain pot. Maybe the gain pot is missing a connection?
SparkyCal
Mar 11, 2020
863
Thanks guys. It turns out that my mistake is the result of two things:
Soldering in the early hours of the morning when the brain is tired
Cramming on too small a PCB
I am doing a rebuild and will; report back.
SparkyCal
Mar 11, 2020
863
Thank-you but when you say:you might try amending the NFB loop with a jfet connected to an envelope follower so the distortion can be controlled by pick attack., it is like talking Mandarin to me. I need it is simpler terms ;-)
VenomBallistics
Aug 30, 2018
285
drive knob replaced with sensitivity.threshold and limit knobs.
these define a sort of virtual drive knob that changes with your pick attack.
SparkyCal
Mar 11, 2020
863
When you say replace the drive knob with sensitivity threshold and limit knobs, which is is the drive knob? the 500K one? and are these sensitivity threshold and limits knobs, special kind of knobs?
VenomBallistics
Aug 30, 2018
285
You said you needed simple terms, so I over simplified it. so we could focus on operational result .... dynamic overdrive.
your 500K can be replaced by a JFET type transistor which will do the same thing, but instead of changing value with a knob twist, it'll change with a voltage level.
Now ... if that voltage is determined by the strength of the input signal, your playing style influences the amount of distortion.
To get that control voltage, we build an envelope follower.
Basically ... I'm doing you the favor of getting you to transition into circuit design
SparkyCal
Mar 11, 2020
863
Don't get me wrong. I appreciate the advice and prompting. When I ask for clarity, it is truly because I don't understand what is being suggested.
SparkyCal
Mar 11, 2020
863
This is strange
I cannot get this circuit to work with the single op amp I am using.
On the op amp, the following is written:
19ALE3M
TL081CP
From this, I assume PIN 2 is the - IN, Pin 6 is the Out, Pin 3 is the + IN , Pin 7 is the VCC in and Pin 4 is ground.
Yet, I have built this many times and it does not work; Further, I get strange Pin readings. Here they are in Volts:
Pin1. .445
Pin2. .096
Pin3. 8.15
Pin4. .454
Pin5. .123
Pin6. .096
Pin7. .517
Pin8. 0
Obviously, something is very wrong. I am wondering if I have an op amp at all, or if the PIN mappings are something other than what I think they are. But I looked up the Pin mappings, and what I stated above, is what I found.
Any advice?
I even attached a pic of the op amp
VenomBallistics
Aug 30, 2018
285
Pin 7 is your + power Pin 4 is - power pin 8 is correct, because it's basically there for decoration
Given your readings, Your just crossed up on your pin connections
SparkyCal
Mar 11, 2020
863
I honestly don't know how I keep screwing this up. I think you;'re right though. I'll report back once I have had a chance to give my head a shake
SparkyCal
Mar 11, 2020
863
So, my eyesight needs a check. I again plugged the op amp in to the socket upside down. I threw it out and put a new one in correctly. Still does not work. Here are my new readings:
Pin1. 6.68
Pin2. 1.2 and falling
Pin3. 3.68
Pin4. 0
Pin5. 0
Pin6. .1.52 and falling
Pin7. 8.12
Pin8. 7.28
Could it be that I damaged a component when the op amp was in the socket upside down?
VenomBallistics
Aug 30, 2018
285
You sure you didn't just get decaf by mistake?
Pin 8 cannot be anything but 0 ... per data sheet, it's has no internal connection
SparkyCal
Mar 11, 2020
863
When I first did this, it was for 2 reasons:
1. I have about 100 of these op amps.
2. I Figured, if I can now build a dual op amp pedal (thanks to you folks- especially AG, Bertus and Harald- trust me, they have been coaching me for longer than I care to admit;-)) , then it should be simple building it with a single op amp, as I won't have to worry about buffering the second op amp (less connections)
So....it is not turning g out as such. I think I may have to give myself a break from this particular build and try it again once I have regained my composure toward it.
BTW VB, I also very much appreciate your help and guidance.
VenomBallistics
Aug 30, 2018
285
ran into the same issue with different parts back in the day.
It was a quad op amp version of the 741. It could be that my data sheets sucked. Ultimately I just migrated to building tube amps because I beat the op amp, hex inverter, and transistor fuzz distortions to death.
Due to the quantity of stock you have, it's probably worth figuring out how to use your 081's though.
Probably a unity gain test circuit to remove any and all variables will get you using them right
SparkyCal
Mar 11, 2020
863
@VB. You're right. As I own about a hundred of these op Amos, I would like to find out how they work. You referred to a unity gain test circuit. I have no idea what that is, but I would be very interested in building one, so I can get to the bottom of this. Is there a schematic you could direct me to?
Thank-you
