JVC HR-S9600U VHS VCR won't play/wind
  • Thread starter William Sommerwerck
  • Start date
W
William Sommerwerck
I bought this a few years ago to play a few tapes. I haven't used it in
about six years.
After it's set up (channels+time), it does everything //but// play or wind.
Other than loading/ejecting, the transport seems dead, dead, dead. (It
"knows" that a tape has been loaded, because -- prior to completing setup --
it automatically ejects a cassette missing its record-safety tab.)
models that can be easily resolved? I have no desire to spend any
significant amount of time troubleshooting or fixing the unit. If it can't
be repaired in a straightforward manner, it will go into storage.
Please -- no tsimmes or megillah. Thank you.
N
N_Cook
about six years.
After it's set up (channels+time), it does everything file://but// play or wind.
Perished rubber belt somewhere, most likely on mode sw motor
W
William Sommerwerck
There are a couple of potential causes for this:
1) The heads are not spinning (motor problem or power supply)
2) The mode switch is not correct (may be dirty/corroded)
3) Belts are slipping
Without seeing the actual unit, it is difficult to determine the exact
problem. Given that this unit has been unused for a long time, I'd look at
the belts initially and clean the mode switrch. If you can do this, post
any progress made and perhaps we can provide additional guidance.
Those sound like simple, straightforward things to look at. Thanks.
W
William Sommerwerck
Perished rubber belt somewhere, most likely on mode sw motor.
Thanks. Appreciated.
W
William Sommerwerck
Perished rubber belt somewhere, most likely on mode-
If I remember this model correcly, the mode switch is
activated by a tab that travels along the underside of one
of the cam gears. There is no "mode sw motor" involved here.
Be careful as it is easy to miss the alignment of this tab.
"Since we last spoke", I found that the capstan isn't turning. (The pinch
roller is tight against it, but the tape isn't moving.)
This is an almost-beltless transport (at least, as seen from the top). The
belt on the loading motor (?) seems to slip when it's time for the capstan
to start moving, but moves at other times.
Further thoughts?
Mark Zenier
about six years.
I've got a rebadged JVC (Magnavox) that's old enough to vote.
Periodically, it needs both the mode switch and the leaf switch
that detects the cassette write protect knockout De-Oxed.
Mark Zenier [email protected]
Googleproofaddress(account:mzenier provider:eskimo domain:com)
W
William Sommerwerck
That is very likely due to the fact that it's stretched and
slick. That particular operation of the transport demands
the highest torque and therefore that's where it slips.
You can try cleaning the slick off with 99.0% isopropyl
or triclor (if you still have any).
I cleaned it yesterday, but there was no apparent change.
Sometimes giving whatever the belt is slipping on a little
push along when it starts to slip will definitely confirm this
diagnosis. Try to find a new belt just slightly smaller, (but
same thickness) than the one presently on the machine to
account for the increase in diameter. PRB used to be a good
supplier of belts. Don't know if they're still around.
I plan to search later today. If the belt is just a few bucks, why not give
it a shot?
I Googled PRB, but nothing appropriate came up.
Those were good machines. It would be a shame to let it go
for a relatively simple problem.
Agreed.
W
William Sommerwerck
Belts should still be available.
They are. (It was used in dozens of JVC VCRs.) It appears to be an
LP30005-003A.
MCM Electronics carries belts, as one example.
This one doesn't show up. JVC sells it on Amazon, but the $5.50 shipping
cost is ridiculous. Encompass had it, too, but with an even higher shipping
cost.
If the capstan belt is slipping, that could account for the
problem.
It doesn't appear to be slipping. When I turn the capstan by hand, the
"idler gear" (that sends power to the hubs) moves away from the rewind hub.
(I'm assuming there's a belt connection.)
To reiterate, the loading belt does not appear to be moving when the point
is reached where the capstan should begin turning.
There are other problems like the power supply not
providing power to the capstan motor.
I'm willing to give the loading belt a shot first.
Where are you located? I have belts in stock
and can send you one in the mail.
Thank you! Please let me know the total cost.
I'm in Renton, WA. I'll send my address in a separate e-mail.
W
William Sommerwerck
The write-protect switch is working, because the unit auto-ejected a
cassette with the tab removed, while accepting one with its tab intact.
I don't know where the mode switch is, and I'm trying to postpone removing
the transport board.
The unit is a remarkable piece of "less is more", especially considering its
plethora of features, prominently splashed across the front panel.
W
William Sommerwerck
Another source of belts, well sort of, are O rings. Several years
ago I picked up a large box of different size unused ones from a
transmission shop. Apparently many shops, when they do a "rebuild"
don't bother to rebuild anything more than they have to, and hence the
spare parts. They are all different thicknesses and lengths, and have
come in really handy.
Thanks for the suggestion. I'm afraid I don't know anyone in the auto-repair
business.
Another question...
I just tried to unseat the transport board (so I could examine its
"boughtum"). I removed the bracket behind the loading slot, then took out
the two large screws at the back of the board. I expected the board to lift
up and out -- but it didn't. (If this were a "junker", I'd rip into it. But
it isn't, and I won't.)
What am I missing?
PS: I was flabbergasted to see what this and other late-model JVC VHS VCRs
go for on eBay -- two and three times their original price. This is perhaps
not surprising, as the playback quality of this model is amazingly good (for
VHS). The TBC and other processing help quite a bit.
