JVC Hv-53pro rear projection TV
JVC HV-53pro rear projection TV. a 53" set.
Fault: There is sound but no picture:
ALL other functions are working fine. However, none of the 3 tubes (R
G B) are working as if no high voltage supplied. Checked the high
voltage supply & it seems OK. I wonder if there is a shutdown switch
somewhere that is activated for no apparent reason. The sound is
perfect.
Any suggestions to resolve this problem is appreciated. Thanks, Paul.
Meat Plow
perfect.
I would make sure there is filament voltage to the crt's. But I also would
presume that a fault like that would shut down the SMPS.
