JVC R-X500 receiver tip and question alt. ref: R-X500B RX500 RX500B R 500 R 500B
Dave Moore
Tip;
Look for damage wherever glue was used.
This set had the wires in a couple of ribbon cables
eaten away where they were glued to the PCB's
Question;
Also the glue damaged a zener diode and ate away
the identification markings on it. To make matters
worse, the bugger was shorted so I couldn't measure
the zener voltage.
From what I could see, there was a "1" and also the
bottom part of either a 6. 8, 3 or 0, so it was probably
a 10, 13, 16, or 18V zener
The set is working with a 16V zener in there now,
but I'd like to stick to the original value if anyone
knows or can look it up for me.
Any help will be truly appreciated.
--Dave--
Dave Moore
Doh!
I got so flustered with ISP problems
that I forgot to mention the location of the zener
that I need to ID.
The silkscreen is a bit damaged, but as best
I kin tell, the location of the zener is D851 and it
is fed power from a 1.8K resistor R856 and is part
of the regulator circuit for transistors Q856 & Q851
Thanks again
Dave Moore
: Tip;
: Look for damage wherever glue was used.
: This set had the wires in a couple of ribbon cables
: eaten away where they were glued to the PCB's
: Question;
: Also the glue damaged a zener diode and ate away
: the identification markings on it. To make matters
: worse, the bugger was shorted so I couldn't measure
: the zener voltage.
: From what I could see, there was a "1" and also the
: bottom part of either a 6. 8, 3 or 0, so it was probably
: a 10, 13, 16, or 18V zener
: The set is working with a 16V zener in there now,
: but I'd like to stick to the original value if anyone
: knows or can look it up for me.
: Any help will be truly appreciated.
: Thanks
: --Dave--
