I
[email protected]
- Jan 1, 1970
- 0
Hi.
I've had the JVC for some years now and decided to give it to my
sister. That's when the trouble started
The receiver will come on and looks like it does everything except
make some sound. Not through the speakers or the headphones. So I
opened it up, checked the all the fuses, wiggled the connectors. Tried
again, hey it works again! Must be a bad connection somewhere. Closed
the case, tried it again no sound <grr>
After some more investigation it seems that the receiver stays mute on
the dvd and the optical inputs, but it will play from an external
analog source. The lights showing the speaker configuration will only
light up on analog/external sources and it will play that source. When
selecting the internal dvd-player or one of the external optical
sources, it goes mute and the speaker lights go off.
Is this a known problem with this receiver? Is there something wrong
with the dsp? Easy to fix and/or expensive to repair?
With kind regards,
Gerben
With kind regards,
Gerben
