KDS Rad-7bk LCD Monitor Distortion
W
Warren Block
This 2004 LCD monitor is nearly working. The onscreen menu is
functional, clear, and sharp.
But the computer image is distorted. It's like every other scan line is
moving back and forth at something like a 30 to 60 Hz rate. Auto-tune
does not affect the problem. Again, the onscreen menu is clear and
sharp while the image behind it has this interlaced distortion.
There were two bulging electrolytics ([email protected], 470uF@16V) on the
control board. Replacing them made no noticeable difference. There are
plenty of smaller electrolytics, but none obviously bad.
There's one online reference to the problem, but no useful solution:
http://www.fixya.com/support/t200283-distorted_picture
Any suggestions? Thanks!
W
Warren Block
I have since replaced all of the larger electrolytics (100 uF and above)
with no improvement. This monitor gets its power from a 12V DC adapter
that plugs into the back of the VGA connector. Video noise happened
both with 12V from a computer power supply and from the AC adapter.
Here's difference between the computer image and the onscreen menu:
http://www.wonkity.com/~wblock/kds/kds-noise.jpg
And here's the controller board. Capacitors with a black mark are ones
that have been replaced:
http://www.wonkity.com/~wblock/kds/kds-controller.jpg
PeterD
If this was my project, I'd put a (good) scope on the various RGB
signals on that VGA connector, and see what they look like. Trigger on
a vertical sync pulse, and move down the scan lines...
I've got to wonder if you are running it at a scan rate that is not
directly supported by this monitor, too. Have you tried different scan
rates (both vertical and horizontal)?
W
Warren Block
Unfortunately, no scope, good or otherwise. Capacitors seemed like a
good guess because of the periodicity of the problem and the two
obviously bulging ones. The controller PC board has a little bit of
heat darkening behind the regulator at the upper left. After removal,
those two small 10 uF caps near it read as 2 to 2.5 uF on my Fluke 79.
There's also some darkening behind the main chip in the center, and the
heatsink compound was only contacting the heatsink at the edges. Fixing
that didn't help, either.
I've ignored the inverter so far because it worked. There are a
couple of small caps on it, and I may replace those on the idea that
the interference is some kind of feedback from the inverter.
Yes, and autotuning the monitor. It displays other resolutions--as well
as it can--and scan rates up to 75Hz. It's consistent and works well...
as long as you don't need to see it too clearly.
W
Warren Block
Working from largest downwards, I replaced all of the electrolytic
capacitors on the controller and the inverter board. Testing of the
removed capacitors showed that many had deteriorated to half or even a
tenth of their marked value. Yet nothing improved until the last five
on the controller. These were three 10 uF, 25V and two 22 uF, 16V near
the toroid inductor. One of the 22 uF was definitely bad.
And that cleared up the distortion. The monitor seems to be fine now.
