Keeping an old dog warm...
jb
Ok all, I'd like to pick your brains for a bit as mine is letting me down at
the moment.
I'd like to keep a hot water bottle or steel plate warm, to allow my dog to
not freeze his knackers off at night.
I've pondered Peltier devices, nichrome resistance wire and electric
blankets.
What would be the best way to keep the bed temperature warm, but not hot?
Say around 40 degrees...
Would nichrome wire be suitable to insert into a hot water bottle to keep it
warm?
A Peltier device hooked up to a smallish steel plate under the bed, much
like a waterbed heater, with a heatsink on the 'cold' side to allow it to
draw sufficient heat from the subzero air/ground?
All help appreciated!
--mark
T.T.
at
the moment.
to
blankets.
it
warm?
--mark
Pet shop.
Not cheap, but reliable and safe.
N
Nicholas Sherlock
You can buy a circular heated plate designed to keep beer warm while
brewing. Perhaps the temperature will be right.
Cheers,
Nicholas Sherlock
Ross Herbert
the moment.
blankets.
warm?
--mark
Australia is a metricated country so when you say 40 degrees on an aus
newsgroup it means centigrade, and that's bloody hot even for a frozen
dog.
read http://www.ozpets.com.au/dogs/articles/DD10061.shtml and consider
a pet electric blanket.
Trevor Wilson
at
the moment.
to
blankets.
it
warm?
**MY mum had an old heated slipped thingy. She was throwing it out, because
the fluffy material had deteriorated. My dog didn't care in the slightest
about the crappy looking material. He slept on it for many years. You could
buy a new heated slipper. I imagine they're made in China nowadays and
probably sell for $19.95.
W
Wing Wong
My friends cat likes to sleep on the amp. The amps basically on full time
so it gets quite warm.
K
KLR
the moment.
blankets.
warm?
--mark
You are probably better off getting a proper heating pad from a pet
supplies for this purpose. probaby a lot safer
for example.
http://www.lovemypet.com.au/mall/more-redflex-heating-pads.asp
With the wattages quoted there (up to 120W !!) I would be very
reluctant to try generating this level of heat in bedding (which is
usually flammable material)
Other things have to be taken into consideration such as what happens
if the dog pees the bed, chews wiring,bedding etc
Trevor Wilson
**Oh, you're one of those? People whose amps have to be cleaned of pet hair,
before service. People whose amps go belly-up prematurely, from capacitor
failure, because they're under the delusion that keeping an amp switched on
24/7 is a good idea.
Mikegw
the moment.
[snip]
--mark
As others have suggested I would go for a pet electric blanket as I suspect
that human ones are not as chew proof.
Mike
RMD
the moment.
blankets.
warm?
--mark
I have an idea pet shops these days sell pet electric blankets for
less than any mucking around you might do.
See:
http://www.ozpetshop.com.au/product_info.php/products_id/532?osCsid=37e0b1281c8eb6b85ec6c5cb43e9cf3a
I have had a pet electric blanket for many years, which I originally
bought in the U.K.
Ross
(To get email address ROT 13)
[email protected]
W
Wing Wong
Yeah, I'm not really a technician, just a EE, but I do the occasional
favour for friends. Pet hair is usually hinders my progress.
rob
the moment.
blankets.
warm?
--mark
I think it was Oatley Electronics that was selling heating tape (silicon
rubber with nichrome?) for doing this sort of thing about 12 months ago.
They may still have some lying around.
An alternative may be an old waterbed heater pad - maybe 2' x 3'. I think
they need to be "heatsunk" to prevent hot spots.
rob
rob
rob said:
news:42b3935e$0$27622$61c65585@un-2park-reader-02.sydney.pipenetworks.com.au down keep
rob
http://www.oatleyelectronics.com/items.html
CSW1 (NEW) CAR SEAT WARMER: Provides warmth and comfort when driving
in autumn and winter. Fits all seats. Connects to the car cigarette lighter
socket (adaptor provided). Features include built-in thermostat, low power
consumption, easy to fix, non-slip and uses elastic strap retainer. $20
dmm
the moment.
blankets.
warm?
--mark
First of all, get the dog off the floor. A bed made from a small circular exercise
trampoline will get the dog off the cold floor and out of any drafts. A couple of
old blankets on the trampoline should also keep the dog warm.
Poxy
down at the moment.
dog to not freeze his knackers off at night.
blankets.
hot? Say around 40 degrees...
keep it warm?
much like a waterbed heater, with a heatsink on the 'cold' side to
allow it to draw sufficient heat from the subzero air/ground?
Our dogs, when they lived outside, had a 25W bulb inside a Milo can wrapped
in wool tucked inside their box (can was earthed of course). The main thing
was the box - sittng on a thick piece of foam and well insulated. Worked
well for small dogs, bigger dogs would need a bigger box I guess.
Mark Harriss
the moment.
blankets.
warm?
--mark
What about a waterbed heater with it's temperature control?.
Sort of like a mini electric blanket with a temp control.
GM
--mark
My sister used to keep pet rats in a set of old kitchen cupboards outside
the house. To stop them from freezing, I took a concrete house brick and
using a Hilti I drilled a hole about 3cm diameter and 10cm deep into the
brick (but not right through to the other side), and I soldered wires onto
a truck indicator bulb 21Watts, 24 Volts. I put the bulb in the brick, and
filled the hole with cement mortar (be careful to stop it getting on the
metal parts of the wires etc. since cement can corrode copper, I forget how
I achieved this). The cable was sticking out through the mortar. I put
the brick in the cupboard (cage) with side with the wire directly against
the wall of the cage so that the rats couldn't eat the cable. I connected
the 24V bulb to a 12V halogen downlight transformer so it would put out
less than the rated power but enough to keep the brick warm, and so it
would last for a long time.
The basic idea is that whatever goes wrong with the bulb, the brick can't
catch fire because bricks don't burn, and the halogen transformer is
supposed to be short circuit - proof too.
To keep the power usage down, a timer or thermostat located where it is safe
from the dog and the weather might be a good idea, and more environmentally
friendly.
Chris
I couldn't resist -
The Real Andy
the moment.
blankets.
warm?
--mark
What happened before dogs had humans??? For **** sake, the dog can
handle the cold, or else he wouldn't be a dog. If it cant handle the
cold then its time to shoot it.
jb
Thankyou, most of you, for your help.
Slipper or car seat warmer looks to be the way to go.
Nichrome underfloor heating tape would not really be suitable; ~230 deg
Celcius is probably a little too hot to have near old blankets and flammable
bedding...
-mark
