Konka TV setup
H
Homer J Simpson
Is there a code to get into the Konka TV setup - the defaults (reset) are
way off viewable?
H
Jumpster Jiver
way off viewable?
H
Never heard of that brand but...
If it is a new TV return it to the store because it is defective.
If you've had the TV for a while and things have changed in the picture
quality then there is a component fault and adjustments will not help,
and will make it much more difficult to get it back to normal after it
is properly repaired.
H
Homer J Simpson
quality then there is a component fault and adjustments will not help, and
will make it much more difficult to get it back to normal after it is
properly repaired.
No, it was a freebie from FreeCycle. And I am a tech, though not for many
years. I suspect someone may have altered the set-up since pushing the
Picture Reset button on the remote jams the contrast up to max.
