Label template for Mircom 1000 fire alarm
F
Frank Olson
Anyone know what Avery label template most closely matches the Mircom 1000
series fire alarm?? Looking for a "faster" solution than designing my
own...
Jim Rojas
MSWord has label formats built into it. You can use plain paper if you are
in a pinch, then just cut it to the right size. MSWord also allows you to
create custom labels from scratch, or alter one of the templates to suit
your needs. Adding dotted lines on plain paper labels makes it easy to cut
them out.
Jim Rojas
F
Frank Olson
I've got MSWord... And the Avery plug in, but there's like 50,000 different
templates... Any idea which one is the closest?? :)
F
Frank Olson
Sadly enough, none match the layout of the Mircom zone labels... Ah well...
Problem's been solved... I spent about 15 minutes configuring an address
label sheet. More than you wanted to know, right??
F
Frank Olson
That looks to be even more time consuming... It's much easier using a label
template and then specifying the size you want and the number of labels on
the sheet. The weird thing with the Mircom labels is that they don't "fit"
any standard template. The reset button, signal silence, and trouble
silence all take up two label spaces.
