latching relay circuit
Jamie Morken
I am trying to make a circuit that will function so that when the power
is disconnected from the running device, and then the power is
reconnected, the device will stay turned off, until it is manually
turned back on with a push button switch. I was told that this could be
done with a latching relay and a DPDT switch, what would the circuit
look like for this? The device runs on 120VAC and draws 15Amps. I have
seen some latching relays on ebay for $1, but I can't figure out how
they would be used to build this circuit! :)
cheers,
Jamie
H
Homer J Simpson
Nope. Just a relay and a push button.
Wire the push button and the NO relay contacts in parallel, and that pair in
series with the relay coil. Wire the load across the relay coil.
mkaras
If you need to isolate the load from the push button circuit, which is
often the case when the relay coil and push button curcuit may operate
on an low voltage DC and the load may be an AC motor on mains power
then it is best to use a separate set of NO contacts on the relay to
switch the motor power.
Look here for some ideas on the relay latch circuit with a push button:
http://www.eleinmec.com/printerpage.asp?24
petrus bitbyter
in series with the relay coil. Wire the load across the relay coil.
Will work fine as long as the pushbutton is rated for the same current (15A
or more) as the relay contacts. Otherwise you better take a double pole
relay and power the load and the relaycoil separately. Keep in mind that the
inrush current may be much more then 15A and that the contacts must be able
to handle it.
petrus bitbyter
Paul Taylor
(15A or more) as the relay contacts. Otherwise you better take a double
pole relay and power the load and the relaycoil separately. Keep in mind
that the inrush current may be much more then 15A and that the contacts
must be able to handle it.
petrus bitbyter
Try this!
http://www.uoguelph.ca/~antoon/circ/alt1.htm
petrus bitbyter
Paul Taylor said:
Nice circuit but the relay used will be too light to switch 15A. To switch
15A (or more, inrush current you know) you need thick contacts and a high
contact pressure. If you can find a relay that can switch the required
current and has a 9V coil, it will need quite some current from the 9V
battery to be activated.
petrus bitbyter
Johnny Chipmelter
petrus bitbyter
C1 R1
---------------||----------===-------------------------------0
| | push button | Thyristor LOAD 16A
| | \ R3 --- |
| D2 |- \ ----===--- \ / Th1 | 230V AC
12V | | + | |------------/ \ \ /
zener --- \ === | | ------- 20A triac
| D1 | C2 | R2 | R3 |
-------------------------------------------------------------0
Solid state solution:
C1 must provide enough current to keep thyristor on and drive triac, should be HV cap.
Resistors R2 R3 only against leakage, some kOhm.
R1 fusible carbon for current limit in case something shorts.
D1 creates stable 12.7V AC wave -0.7 to +12V.
D2 rectifies this wave.
C2 smoothes the rectified wave.
Th1 will latch if button pressed.
R3 limits peak gate current.
IIRC triac can be driven positive on gate in all quadrants?
This solution can sometimes be cheaper then a relay.
Circuit not tested, use at own risk.
H
Homer J Simpson
Rube Goldberg would be proud.
Use a regular contactor, wire a set of NO contacts in parallel with the
pushbutton - normal motor starter set-up.
Jamie Morken
On the relay it says 150V/15Amps or 300V/10Amps. Why does the current
rating go down with increasing working voltage?
cheers,
Jamie
H
Homer J Simpson
It's more the ability to open the circuit that is the key.
