F
fancy nospam tunes
- Jan 1, 1970
- 0
Thinking of buying a variable DC power supply to recharge an electric
scooter's sealed gel lead acid battery. However, when trying out two
models from the same manufacturer, their voltage displays aren't
consistent:
The less powerful model (0-3amps) shows actual voltage, as it rises
from actual voltage, until it stops at the target voltage [using
Constant Voltage mode.] Whereas the more powerful model (0-10 amps)
shows only the target voltage; requiring the user to use a multimeter
to view the actual, rising, voltages. I personally prefer to see the
actual voltage.
Can someone explain why these power supplies' displays differ?
Second newbie question: Is the more 0-10 amp unit a more
"professional" design? I'd like to have a power supply that doesn't
self-destruct as soon as the warranty expires.
All perspectives totally appreciated. Cheers!
consistent:
actual voltage.
