Leakage problem driving one SSR with another
Bouquet
I'm controlling a high-current SSR with a lower-current SSR module
but have found that the 4mA leakage of the module is causing the
high current module to stay on permanently. The high-current SSR
has an impendance of 20KOhms and the control voltage is 240V AC.
I've calculated that a 5-10W resistor would be needed across the
SSRs to drain the leakage, but is there any other device I could
use to sink the 4mA @ <20VAC in the SSR off-state but not much more
current in the 240V on-state? Some AC constant current device, a
neon lamp maybe.
I'd appreciate any help you could offer.
Mark
W
Walter Harley
I don't know the answer to your problem (hopefully someone else does). But
I wonder whether there is an alternate approach?
Seems to me, you only need to control 12mA of AC (to power the high-current
SSR). But your low-current SSR has *leakage* of 4mA, suggesting it's not a
very low-current SSR after all. Maybe the answer is to get a smaller
low-current SSR, one that has less leakage?
A brief web search shows, e.g., the Crydom AO241, with control voltage of
4-10v @ 15mA, leakage current of 0.1mA, max load current of 1A. I'm sure
there are a bunch of other ones, that's just the first one I found.
Daniel Lang
You may want to use a photomos optoisolator to drive the high current SSR.
Something like the NEC PS7141-1A or NEC PS7160-1A from Digikey should work
fine (use the 2 drain pins and leave the common source pin open).
Dan
Boris Mohar
neon lamp maybe.
Mark
Put an AC capacitor across the input to shunt the leakage.
Regards,
Boris Mohar
Got Knock? - see:
Viatrack Printed Circuit Designs http://www3.sympatico.ca/borism/
Aurora, Ontario
