W
Wayne R.
- Jan 1, 1970
- 0
I've got several dry contact alarm leads (telecom environment) that I
need to piggy-back onto each other into a single reporting pair of
leads. I think that, with each as normally open, the one that closes
could be identified if that particular line has an LED included.
In other words, I want to tie in parallel several relay closures to a
single detection circuit. And I'd like to put an LED on each
individual relay line so we'd know which one is the guilty party when
something is tripped.
The voltage on each detection circuit is the available voltage from
our 48VDC plant - usually at 54VDC when on commercial AC, but at 48VDC
(or lower) when on batteries.
Can someone define for me and LED/resistor combination that will work?
Or, better yet, is there a way to do this simply with supervised/NC
circuits?
circuits?
