Led light bar
Aphayes1
Aug 12, 2017
3
Hello this is my first post but i will be posting more due to upcoming projects.
I was wondering if anyone can tell me an easy circuit for a light bar, what i want it to do is light up one bar at a time with the press of one button then go down with the press of another, the project is a startrek phaser.
i will also be wiring in a laser module and another led but that will be the easy part ''i hope''
I just have no idea on how to do this part of it.
Any help would be greatly appreciated, thank you.
This is the type.
https://www.sparkfun.com/products/9938
dorke
Jun 20, 2015
2,342
A universal shift register should do the job for you.
If you had used only 8 LEDs the 74HC299 would be a perfect choice.
One side input is permanently shifting in "1"s ,
the other is permanently shifting in "0".
You will control the direction of the shift with S0,S1 lines(via switches).
And clock the device with a low speed clock.
Aphayes1
Aug 12, 2017
3
but im usding a bar as its the perfect fit and others have used these to gfive the ull effect.
dorke
Jun 20, 2015
2,342
You can add another IC to get 10 bits
,not a problem.
Would a "volume knob" instead of the switches be o.k?
dorke
Jun 20, 2015
2,342
So,
You need to cascade two 74HC299 to get 10 bits.
That would be a nice little project for you.
Try it and you can get some help here as well.
If you knew some VHDL you could program a small PLA to do the all thing.
It can be done with a uC as well,some software knowledge is needed for that.
