Led lighthouse
turbogt16v
Mar 27, 2015
176
Hy
I need code that will act similar to this light
And would also like to know what function do i use to turn off that code lineary when swich comes on ,in about half second
turbogt16v
Mar 27, 2015
176
Ok,so i got it running and the code seams litle to linear how can i upgtade code for somethimg more exponential light curve,so the light would seam more natural,the only thing that looks live in this code is peak ,that gives it a litle life,but i want light to keep brightness level different at different level of brightness.
turbogt16v
Mar 27, 2015
176
Ok here is a little scech of my code and the one i woul like to make
turbogt16v
Mar 27, 2015
176
And another question do i need a resistor between source and adruino gtound,and what walue
turbogt16v
Mar 27, 2015
176
Ok so i have a problem, when i connect mosfet led and adruino,the led wont start unles i tap the gate of mosfet with finger.
I tried warious values of resiator between gate and source,but no help to start code ,led only freezes in secound i tap,and stays in that lightning level,
Doni need transistor or what
duke37
Jan 9, 2011
5,364
A fet has a very high input inpedance and the gate voltage will stay where it is put if not connected to anything else.
Does the output of the arduino provide sufficient voltage to switch the fet?
turbogt16v
Mar 27, 2015
176
I power led and audrino from 9v 300ma
Ok i tried 12v 1,5a and it works
duke37
Jan 9, 2011
5,364
The arduino (never used one) will not give out 9V, it will be run from 3.3V or 5V. 5V is necessary to turn on the irl520 logic level fet. A low value resistor from gate to source will reduce the drive voltage.
