LED string
colum
Jul 25, 2013
180
I have a mechanical arm that has 4 limit switches that is hooked up to 4 LEDs. 3 of the LEDs light up fine when activated but the last LED of the chain seems to take all of the power of the 9v battery when activated
I have switched LEDs etc but always the last Led prevents the first 3 from lighting
What value resistors do you have in series with the LEDs?
colum
Jul 25, 2013
180
Thank you for responding Steve...One resistor at input + 330 ohms....colum
Let me guess, the last LED is red and the others aren't?
You should have a separate resistor for each LED.
Ok the basis of what you have now, four 1.2kΩ resistors should do the trick.
colum
Jul 25, 2013
180
Thanks Steve, I did try a Red a Green and a Blue
and thanks for the resistor placement and Ohm advice
colum
