Leslie Hot Rod
Trevor
To whom it may concern,
I'm trying to biamp my new Leslie Speaker model 122A. My master plan
is to use the stock 40-watt amp to drive only the horn and a Mackie
SR1530 for the low-end duties. The Mackie is a solid-state tri-amped
system. In this scheme, I won't need the services of either the Mackie
mid or upper drivers. In other words I'll be using the Mackie amp to
power only its woofer, which now resides in the Leslie cabinet.
Here is the cut and paste spec sheet for the Mackie SR1530:
SR1530 Specifications
System:
Freq. Range (-10 dB)
40Hz - 20kHz
Freq. Response (-3dB)
45Hz - 18kHz
Horz. Coverage Angle (-6dB)
90°
Vert. Coverage Angle (-6dB)
40°
Directivity Factor; DI(Q)
10.77 (11.95) averaged 2kHz to 10kHz
Rated Maximum SPL (peak)
126dB @ 1m
Crossover Points
700Hz, 3,000Hz
Transducer:
Low-Frequency:
Diameter
15-inch (381mm)
Power Handling
300 watts Dynamic Program Power
Mid-Frequency:
Diameter
6-inch (152mm) diameter
Power Handling
100 watts Dynamic Program Power
High Frequency:
Exit Throat
1-inch (25.4mm)
Power handling
Amplifiers:
Low-Frequency Power Amplifier:
Rated Power
300 watts @ Low-Frequency Driver Impedance
Rated THD
< 0.05%
Cooling
Class AB Convection Extrusion
Mid-frequency amplifier:
Rated Power
100 watts @ Mid-Frequency Driver Impedance
Rated THD
<0.01%
Cooling
High-frequency amplifier:
Rated Power
100 watts @ High-Frequency Driver Impedance
Rated THD
<0.01%
Cooling
Being more musician than electrician results in the following
Shortcomings of knowledge;
Do I need a load of any kind where the mid and upper drivers were so
the Mackie amp doesn't suffer any ill effects from only being
connected to the woofer? (e.g. make amp run to hot, not at peak
efficiency, shorten its life, etc…)
If I need to have a dummy load where the mid and upper drivers were,
what is the best way to go about this. Just wire in the appropriate
resistor? If so what is the appropriate resistor?
The Leslie 122A is a 40 watt tube amp. I plan to put a load (16 ohm
10 watt resistor) on it where the original woofer was after the
crossover. Is that the best way to do it? The way I understand it
the woofer, driver and crossover all are 16ohm in the Leslie 122.
I would like to optimize the power going to the driver w/o alteration
of the driver's sound. Will running the amp into the crossover then
into the upper driver with a dummy load where the woofer was complete
the task? Or am I missing something here?
The driver is the new Leslie Ferro-fluid 100 watt driver.
I would be much obliged for any help I can get on this project.
Thanks.
Sincerely,
Trevor
jakdedert
I'd keep the Mackie 'as original,' sell it and get a pair of power amps and
2-way electronic crossover for the Leslie. I've seen several setups like
that, replacing the original tube amps completely. Is this an older model
Leslie, or something new? The setups I refer to are the units which came
with the original B-3's. There are tons of mods out there for those. I'm
not familiar with the newer models.
Of course, if you want to keep the tube sound, your options are a bit more
limited, but you could still sub in a mono solid state amp for the low end,
and a cheap crossover can be had for $100 or less used. I've even seen
people drive them with a guitar amplifer head. Just make *very* sure that
the horn driver only gets high frequencies.
jak
