Limit switch to control motor
N
Norman Pirollo
Need some advice..
I am designing a small feed system for lumber grading.
This feed system is part of a lumber grading system.
There is a motor drive feeding the individual boards along a
horizontal surface using rubber wheels or rollers.
The feed motor is started manually with a magnetic switch.
At a certain point the piece of lumber should activate a limit or
proximity switch indicating the lumber is correclty against the
horizontal surface of the grading component ( very important to
correctly grade)
If the board rises above the surface , even as little as 1/3 in., the
limit or proximity switch should shut the feed motor down using the
same magnetic switch used to start it..(severly warped board, etc..)
I wish to use one limit/proximity switch to do this.
The difficult part is that the switch is normally open while the board
is being fed through, then becomes closed, then open if there is a
problem.
The open switch then needs to shut the feed motor down...
I have been looking at metal roller ball type switches, preferably
dust-proof and rugged.
How to perform this trickery?
Norman
Rock
Norman,
Most micro switches such as the one you describe have three contacts so that
you can wire them as normally open or normally closed. If I understand your
problem correctly you would connect it in series with the coil of a relay
controlling the motor and wire the switch in the normally closed condition.
Gary
Ross Herbert
Need some advice..
correctly grade)
problem.
Norman
You will need to use an industrial limit switch such as the 9007AW
shown here
http://www.us.telemecanique.com/us/...56A1F0057EAEE/$file/HeavyDutyIndustLimits.htm
the SPDT and DPDT types have changeover contacts (single or double
contact) so that you can use the NO or NC side of the switch for your
purpose. You can obtain application information from the technical
library here
http://ecatalog.squared.com/techlib/browse.cfm?hid=0b008926800af21a
N
Norman Pirollo
Thx for the links....
I'm still stumped on how to toggle the switch, then monitor same
switch if piece rises above surface. Toggling the limit switch on
should do nothing, but if the switch turns off, then it will release
the motor dricve
at the mag. switch
Looks like I'll need a circuit which is normally set, then if unset,
will release the magnetic switch powering the motor.
John Fields
the motor dricve
at the mag. switch
The circuitry required to do what you want isn't difficult to come up
with, but what's confusing (to me, anyway) is the sequence of events
leading up to the piece of lumber engaing the switch and then the
criteria used to determine if/when the feed motor should stop.
Could you describe the grading process in greater detail and how the
lumber is handled from start to finish, please?
N
Norman
Thank You all, looks like I need to look at this design a little
better..
