No no no! This is not a heliostat. A heliostat is
generally a flat, or nearly flat, mirror reflection light
onto a stationary target.
Sorry about the confustion. I meant to say that the hardware was very
similar to a heliostat, not the direction of pointing. The 24" diameter
pedestal tube, the Winsmith gear drive, the 12" diameter torque tubes, the
truss structures (to create the flat surface), the drive motors, and the
control hardware were all previously designed for use as a heliostat. Since
heliostats do not point directly at the sun, the control system software
must have been modified.
My understanding is that the encapsulant has been improved
to handle a bit higher temperatures with longer lifetimes.
The encapsulant is not deteriorated by higher concentration
factors. It's temperature that is the problem.
True, but without active cooling, the higher concentration will result in a
temperature increase. I have no information on the allowable temperatures
of the new EVA. Have you heard anything about it?
The Sunpower PV panels with a flux of 1000 watts/m^2 can convert about 20%
of that energy into electricity. That leaves 800 watts to be convected and
radiated from both sides of the panel. Assuming 3/4 of the thermal load is
taken off the front surface and the emissivity of the panel is 95%, the
temperature of the surface should raise about 49 degrees C above ambient.
The convective heat transfer coefficient on the front surface should be
about 5.33 W/m^2C without wind. I was suprised that the PV surface was that
hot. Does that sound reasonable?
With a net concentration of 1.75, there should be 1750 watts/m^2 arriving on
the panel (a little conservative since 1/3 of the indirect solar flux will
be blocked by the mirror.). I expect the overall conversion efficiency will
be reduced to 18% or so with the higher silicon temperature (will need to
verify this assumption later). That should leave a total of 1475 watts of
thermal energy. Assuming the same 75% heat transfer from the front surface,
the surface temperature should rise about 78 degrees C over ambient and the
new convection heat transfer coefficient should be about 5.81 W/m^2C in
perfectly still air. That's about 29 degrees C higher than the
non-concentrated case. .
The ambient temperature in the desert can get as high as 49 degrees C (120
F), so I assume the PV panels were designed to be reliable at this
temperature. Luckily, I don't live in the desert and my maximum ambient
temperature is about 38 degrees C. This is still about 18 degrees C hotter
than the panels were probably designed to operate. Is that a problem for
the new EVA?
Are any of these designs still under patent protection or have they fallen
into the public domain?
And some others.
I have asked many PV manufactures about their warrantees.
They don't actually say that concentrating is prohibited.
They do say that over heating the panel is grounds for
violating the warrantee.
Since temperature is the problem any way to help cool
the panels is a plus. Heat sinks and water cooling has
been effective.
I have been proposing the use of heliostats, yes real
heliostats, that reflect light onto stationary PV panels
mounted vertically and facing north. 1 to 4 heliostats
reflect light onto the panels. A temperature sensor
along with the heliostat controller adjust the number
of heliostats aiming at the panels.
Do you expect difficulty keeping all of the PV panels evenly concentrated
with the heliostats because the reflected shape will change so much
througout the day? In other words, a heliostat with a square mirror will
reflect a stretched parallelogram during early and late hours, right? Can
you keep the entire PV area uniformly covered? Is this an issue or not a
big deal?
Of course, cold weather allows more concentration
without exceeding the maximum temperature.
Then Minnesota winters should allow higher concentration
Thanks for the reply!
John Symons
Duane
Home of the $35 Solar Tracker Receiver
http://www.redrok.com/led3xassm.htm [*]
Powered by \ \ \ //|
Thermonuclear Solar Energy from the Sun / |
Energy (the SUN) \ \ \ / / |
Red Rock Energy \ \ / / |
Duane C. Johnson Designer \ \ / \ / |
1825 Florence St Heliostat,Control,& Mounts |
White Bear Lake, Minnesota === \ / \ |
USA 55110-3364 === \ |
(651)426-4766 use Courier New Font \ |
[email protected] (my email: address) \ |
http://www.redrok.com (Web site) ===
