Liteon VCR/DVD Player/Recorder Odd Problem
Brad
I have a "Liteon" brand VCR/DVD recorder/player model LVC-9006 in my shop
(no SM). When you plug it in, it comes on with the "Hello" message "frozen"
(doesn't change). You can't turn off the unit (stuck in power on). You can't
open the DVD drawer. The VCR wasn't used when this happened and there is
no tape in the VCR. The VCR mechanism is in the proper position for no tape
present. The customer had a DVD inside (it won't play). I removed the DVD
assembly, removed the DVD, cleaned the head while I was at it although I knew
it wasn't the cause of the problem. I didn't put the DVD in the drive when I
installed it.
I tried a tape in the VCR. The tape was loaded, but it wouldn't play. I
couldn't eject it so I did it manually.
I looked for something visually that might be the cause. I checked
connections and cables to see they were all secure (properly plugged into
their connections).
Did you have this problem with this brand unit?
Thanks in advance, Brad
Before you type your password, credit card number, etc.,
be sure there is no active keystroke logger (spyware) in your PC.
Mark D. Zacharias
Brad said:
my shop (no SM). When you plug it in, it comes on with the "Hello"
message "frozen" (doesn't change). You can't turn off the unit
(stuck in power on). You can't open the DVD drawer. The VCR wasn't
no tape present. The customer had a DVD inside (it won't play). I
removed the DVD assembly, removed the DVD, cleaned the head while I
was at it although I knew it wasn't the cause of the problem. I
didn't put the DVD in the drive when I installed it.
play. I couldn't eject it so I did it manually.
into their connections).
I would at least look for noisy power supply lines - high ESR caps and the
like. If for example a critical voltage had a high frequency waveform riding
on it, the unit may not reset properly, or one circuit or other may just see
a "low" DC voltage.
Mark Z.
