LM2596 inductor, capacitor, diode
holex
Jun 2, 2014
21
I have an LM2596 5.0, and I would like te build a power supply for an AVR (+LCD+sensors, etc..) and a servo motor (MG946R), so I need 3A and 5V. The input voltage 35V. What capacitor, inductor and diode I need? I can't understand the datasheet... What else should I need pay attention when buying the parts? For example I heard, that I need a closed core inductor.
Thank you!
OLIVE2222
Oct 2, 2011
690
Hi and welcome to electronicspoint !
You can use the TI friendly webench tool, see here under, for all the parts calculations
http://www.ti.com/product/lm2596
You must create and account to do that. The tool allow components tuning to match your sources or footprints needs.
Closed inductor (toiroid) are better as the fields are confined, giving less impact on surrounding parts.
This is not mandatory but just an asset. The routing is not that sensitive, i suggest to start from the datasheet layout.
My two cent to make your life easier is to buy an hard to beat LM2596 board from ebay
http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_nkw=lm2596&_sop=15
Olivier
holex
Jun 2, 2014
21
Thank you very much for your help, but webench can't calculate with through-hole parts, only with SMDs :(
OLIVE2222
Oct 2, 2011
690
The component mounting method don't impact the design that much. You can also create customs parts by entering the main characteristics according to the parts you intend to use.
Olivier
holex
Jun 2, 2014
21
OLIVE2222
Oct 2, 2011
690
holex
Jun 2, 2014
21
Yes, I used, and due to simulator these components are good, but somebody said me that the inductor is too big... So I dont know whom to believe.
OLIVE2222
Oct 2, 2011
690
If you have room enough you can go for a big inductor, the will offer a lower Rdc what is a good think!
holex
Jun 2, 2014
21
Ok, thank you! And isn't it problem, that the inductor is not shielded?
