Looking for part name
I need to build a custom electrical connection for a hobby project.
Back in the days when I used to help build cable, we had stocks of male
and female pins that we inserted into RS-232 cable terminators. I would
like to get solderable pins/recepticles of this type to make my own
connector.
What would these be called in major catalog?
It looks like www.allelectronics.com has the MALES under "MOLEX Pins",
MP-100 but not the females.
I thought "contacts" would be the right term but, Digikey e.g.,
"Contacts, see connectors" nothing under Connectors, contacts.
Peter Howard
connector.
I had precisely this problem the week before last when I used the last of
about 200 I had. I thought they were called Molex receptacles too.
Go to www.jaycar.com.au and search for HP1260 in the top left keyword/cat.no
box.. Click picture for an enlarged view. That's what I was looking for.
$4.25AU for a packet of 25. Ouch. They have an insulation holding ring crimp
and a further crimp to grip the bared wire. You break them off the bearer
strip. I add a tiny amount of solder and some heatshrink. Slide firmly onto
a .9mm PCB stake. This is an Australian website and you're probably not in
Australia. But if this is what you have in mind and if you are
desperate.....
PH
Peter Bennett
connector.
Might be called "insertable contacts" or "insertable pins/sockets".
There are many connector families that have insertable contacts -
since you mention the ones you used were in RS-232 connectors, look
for Canon or AMP D-Subminature connectors. Both makes come in
insertable-contact versions, and the insertable pins and sockets
should be listed near the connectors that they fit.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
