looking for power mosfet
lmcclaf
I have an Epson projector here that has a shorted Mitsubishi power
mosfet part number FK20KM-5. I've been searching but so far I've been
unable to find a place to order one from. I'm located in Canada. Can
anyone shed some light on where I might be able to order one? Thanks
for any help.
Cheers,
Lawrence
K
kilowatt
for any help.
Cheers,
Lawrence
Hi L
Made by Mitsubishi and Powerex corp. Look on Datasheets4U.com using
the FK20KM-5 as search word. Any N channel power mosfet will work, but
look for one that has 250 volt rating at 20 amperes. Seems that the
device has high voltage isolation so use a beryllium wafer type washer
to provide insulation to mounting surface..
Made mainly by Mitsubishi Electric Semiconductor but also avail from
Powerex Power Semiconductors. Look on the data sheet for address I
think...
kw
lmcclaf
Thanks for the response. I've got the datasheet for both the -5 and
the -6. The -6 is just a 300V version of the -5. I did find one place
that sells them but they are currently out of stock. Both the -5 and
the -6 are "on their way out the door" according to the Mitsubishi
site so I'll probably check out some equivalent types. Thanks again.
Cheers,
Lawrence
