Looking for quality 128Gb USB stick
Pete
I'm looking for a good quality 128Gb USB stick.
Some of the smaller (ie 8gb, 32gb) sticks that I've purchased over the
last year or so have become faulty, or the connector (tin, held on with
solder) has become intermittent, so I'm not terribly impressed with the
general quality that's around.
So far, the sticks that use the circuit board for the USB connection
instead of a separate connector seem to be the hardiest, but I haven't
been able to find a 128Gb stick with this feature.
The stick doesn't need to be bullet-proof, or hermetically sealed, but
it will spend some time in my pocket and on my keyring.
Does anyone have any ideas? I'm in Melbourne if it matters.
Thanks, Peter
Bob Milutinovic
The stick doesn't need to be bullet-proof, or hermetically sealed, but it
Thanks, Peter
The SanDisk Cruzer should fit the bill - $129 from OfficeWorks,
http://tinyurl.com/SDCZ60128G
I haven't used this particular incarnation of the Cruzer, but I still have
an 8Gb one I bought in early '08 and it's still going strong.
Damian
Thanks, Peter
brands like Sandisk are relatively more reliable.
What kills them, is the time it's left plugged into the USB socket(do the
work and unplug). The heat apparently is on of the causes of USB stick early
death.
Always dismount before unplugging.
Never rely on windows guarantee that it can be pulled out without 'safe
disconnect'.
Other thing is that voltage spikes from motherboard also a killer. USB
sticks tend to die when the PC suddenly turn off or turn on while the stick
is already plugged in.
Cheaper ones are more prone to that kind of death.
Verbatim is another good brand.
Stay away from no name brands and funny name brands you've never heard of.
Stick with reputable brands, and it's worth few extra dollars.
SG1
early death.
disconnect'.
stick is already plugged in.
My Verbatim 8GB is the slowest drive I have, avoid at all costs.
Damian
Check your motherboard USB port of the hub. That may be the reason.
SG1
It is slower than noname brands and Woolies homebrand on the same port. It
is shit.
Damian
is shit.
May have something to do with USB version?!
Mine are fine and have been going for years without dramas.
Noname crap has been dying on me for years.
Either way, they all are prone to sudden death.
Rod Speed
Not when the other drives go at a decent speed.
Damian
Rod Speed said:
Nope, its due to the speed of the ram inside it.
Did you mean the tiny amount of RAM inside the microcontroller?!
Damian
Rod Speed said:
Nope, the ram on the USB stick.
I prefer to call them flash memory. It's somewhere between standard ROM and
RAM. It's fairly different type of chip from the ones used in computer RAM.
I think it's closer to ROM 'cos it's nonvolatile memory.
It's much slower than computer RAM.
Have you ever opened up a verbatim usb stick?
What brand chips do they use that makes them slower?!
SG1
and RAM. It's fairly different type of chip from the ones used in
computer RAM.
EPROM
Rod Speed
They're both. And whatever you call it, it’s the speed of that that’s the
problem.
It's somewhere between standard ROM and RAM. It's fairly different type
of chip from the ones used in computer RAM. I think it's closer to ROM
Nope, haven't had one fail.
Should be on the net somewhere.
Damian
problem.
Yes. They are a hybrid of ROM and RAM. perhaps why they invented the name
flash.
Exactly! That's why I like them. Even if it's bit slower, who cares?! if it
doesn't stuff up your data out of blue.
I opened up numerous ones icluding my very first more than ten years ago.
I've never been able to fix a single one. When they stuff up, it happens
inside the black box most of the time.
I believe it's the controller chip that shits itself, not the actual memory.
Somebody with sufficient soldering gear and experience can recover the data
with a new chip or some other bypass technique.
Jasen Betts
flash.
they're not like ram, you cant rewrite random addresses.
the behviour is closest to EEPROM
Damian
Yes. we know. It's been already agreed above.
