Looking for replacement speaker for Mitsubishi CK-31302 Television.
The left speaker on my parents Mitsubishi CK-31302 TV doesn't work
anymore. Mitsubishi does not have a replacement speaker since the tv is
over 10 years old.Is this a generic speaker that Radio Shack might
carry?Is it a full range or mid-range speaker? Do i need to know
impedance, ohms, or wattage to match it, or would the people at Radio
Shack know by looking at it.?Also, would it be better to replace both
speakers?The speaker or instruction book which came with the tv doesn't
mention specs. Thanks.
Jerry G.
If you remove it, you can take it around to the electronics parts
distributors in your area. I am sure that they may be able to sub it for
you, unless it is a specially made one to fit in a specific way.
Considering that the new one will most likely not be sonically matched, I
would change the speakers on both sides at the same time. You may find that
if you do not, they will sound different. There is also a large age factor
there as well.
Jerry G.
Shoreline Electronics
Make sure the impedance is matched to the OEM one and also make sure that it
is a shielded speaker other wise you will have purity issues on the CRT.
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
[email protected]
Mark
are you sure it is the speaker?
swap the wires and check
Mark
