Looking for simple 555 relay circuit
Z
ZhangLu
Hi all,
Looking for a circuit diagram (on trip board) that utilizes ic 555, using
12V AC power input that:
On when pressing a switch
Off when pressing the same switch
Beeps every 10 sec.
Drives a 12V 55W light (AC or DC)
Can anyone help?
Regards,
New learner
JeffM
New learner (ZhangLu) asks:
555, using 12V AC power input that:
Easy so far.
Not a problem.
Beeps every 10 sec.
How long does it beep?
Be much more specific: When does it light; when does it go dark?
In the future, basic questions should remain in sci.electronics.basics.
Terry Pinnell
Easy so far.
Not a problem.
My guess would be say 500mS. So an astable with appropriate duty cycle
would drive it. And it could be gated by a flip-flop, triggered by
momentary switch contact.
But what device is to be used for the beep? A DC buzzer? If it's a
miniature loudspeaker, a further circuit section is needed to provide
the oscillator. At what frequency?
Fair point - I suppose I'd have assumed it would light simultaneously
with the beep. IOW, a Beep & Flash alarm of some sort. But it would be
good not to have to guess <g>.
How important is it that it to use a 555? At first sight I'd have
thought it easier to implement with CMOS 4001/4011. The light
requirement means a relay is needed anyway, so one major merit of 555
- its 200mA direct output drive current - is of no consequence. And
although you can make a F/F (bistable, or 'toggle') with a 555, it's
more usual to use a couple of logic gates.
BTW, I take it this is not homework?
Z
ZhangLu
Thanks for your reply.
The bulb will light on when the switch is pressed once, and the DC bleeper
will beep every 10 sec simultaneously as a 10 sec counter until the same
switch is pressed again to stop both the light and bleeper.
Z
ZhangLu
Thanks Terry.
I'm a new hobbyist trying to play with 555. If you think CMOS 4001/4011 can
do the trick better, are you able to suggest a circuit for me to work on?
TQ.
Soeren
Hi Terry,
I assume from this:
"On when pressing a switch
Off when pressing the same switch"
That the lamp should be considered the output (on = light and vv.)
The next part: "Beeps every 10 sec." I see as something independant of
the switching ?
Something _similar_ to a manualy controlled photographic enlarger with
beeps to mentally count off the interval at hand ?
Terry Pinnell
By 'switch', I assume you mean a momentary contact push-button? As I
said earlier, that will require a simple flip/flop (toggle) followed
by a gated astable.
But must you use a push-button? If you used a simple SPST switch
instead, then you could eliminate the toggle. You would switch control
directly to the lamp circuit, and off again (a relay, switching higher
power to the lamp). And that same signal would gate the astable, which
would drive the DC beeper.
If it *does* have to be a push-button, please confirm that this is the
intended timing diagram.
http://www.terrypin.dial.pipex.com/Images/LightBeeper.gif
Z
ZhangLu
G'day Terry,
Thanks for the diagram, that's exactly the timing I intended to have. The
switch is a momentary contact push-button.
ZhangLu
New Learner, Malaysia
Soeren
Hi ZhangLu,
The switch is a momentary contact push-button.
Thought so :) But what precision do you need in the timing of the 10
second intervals ?
If demands are not too strict on timing, it could be build with...
1 CD4093, 3 transistors, a couple of diodes, a few caps, ~12 resistors, a
small (32 Ohm?) speaker, a relay and the pushbutton.
Regards,
Soeren
* If it puzzles you dear... Reverse engineer *
New forum: <URL:http://www.ElektronikTeknolog.dk/cgi-bin/SPEED/>
Terry Pinnell
ZhangLu said:
G'day Terry,
ZhangLu
OK, here's a circuit to do it. It contains full notes, so should be
self-explanatory, but post again if not clear. Breadboarded and works
fine.
http://www.terrypin.dial.pipex.com/Images/LightBeeper-ZhangLu.gif
Many alternative designs are possible. And you could use a relay for
driving the high power lamp if you have a suitable one to hand,
instead of the power MOSFET I've recommended.
Terry Pinnell
Soeren said:
Hi ZhangLu,
second intervals ?
Far fewer than that <g>. See
What were you proposing to use around 12 resistors for?
Terry Pinnell
fine.
[etc]
One point I forgot to mention. C2 must not be a polarised type. In
this case I connected a pair of identical 10uF electrolytics in
series, back to back (-ve ends together). That effectively gives a 5uF
non-polarised equivalent.
### 10uF |
| | = 5uF
### 10uF |
Soeren
Hi Terry,
Well, that _won't_ work, so you get a (free) extra try ;)
Making it work ;) (with bipolars, including one used as inverter), with
10 sec. period adjustable +/- ~2.5sec and generator for the beep sound
into a speaker.
<URL:http://www.ElektronikTeknolog.dk/Circuits/PB-ON-OFF_w_beeper.gif>
Regards,
Soeren
Z
ZhangLu
Thanks everybody!! I've learned a lot from all of you.
BTW Terry, may I assume that this circuit works on 12V DC and the
+ve input is around C3?
I intend to use a heavy duty relay to replace Q1 MOSFET to drive the 55W
lamp.
Again, thank you so much.
Regards,
ZhangLu, New Learner
Malaysia
Terry Pinnell
Soeren said:
Hi Terry,
As I said, "Breadboarded and works fine." Would you like to see a
screenshot of its output? And it simulated OK too. There's always the
possibility that I've drawn a different circuit to the one I simulated
and built, but at a quick check that doesn't appear to be the case.
What are your problems with it?
Terry Pinnell
Fred Bloggs said:
Have you taken to heavy drink or something? U2A-B state is indeterminate
when S1 is open,
Agreed, but I hardly think that matters in this application, do you?
One press of the button, if necessary, if he wants to 'start' with
light and beeping OFF.
And the purpose of U2D/ C2 to Vdd is too subtle to discern.
Ah - I now see I *have* drawn it incorrectly, sorry! U2Cpin8, C2, R3
and D1 share a common node, but do *not* go to Vdd, as you rightly
point out, thanks.
Terry Pinnell
Obviously *too* quick! Fred's post prompted a closer look and I've now
corrected that silly drawing error. Any more problems with this
working circuit?
Terry Pinnell
Yes, it works fine at 12V. I assume you have the corrected schematic?
Pins 14 and 7 of the 4011 (or 4093) go to 12V an 0V respectively.
lamp.
OK. Instead of wiring to the gate of MOSFET Q1, use a simple relay
driving section like that in Soeren's circuit.
Soeren
Hi Terry,
Yup :)
I guess you are one of the build-first-make-drawings-later kind of guys ?
Even if you are, build after the schematic when it is finished, or better,
let somebody else build it up, it will catch all these drawn-late-in-the-
night errors :)
working circuit?
Not except that you cannot adjust the timing and you have to use a buzzer
instead of a cheaper "loose" piezo disk ;)
(Just teasing you know :)
Regards,
Soeren
