Looking for this switch (Midas Venice solo switch)
Eeyore
I'm repairing a Midas Venice mixing console. Try and avoid doing so.
It's a nightmare
Despite the agent's tech insisting that the 'solo' switches are 'self
cleaning', no amount of exercising them will prevent 2 of them behaving
intermittently.
They are pcb vertical mount types, i.e. the control surface is a series
of large flat double sided boards. From appearance I guessed the
switches to be ALPS but the German parts list gives the following
reference as best as I can decode it.
SCHALTER-TAST 4XUM 1 switch 4pdt
It's a latching type btw.
Any help sourcing same would be appreciated. I only need 2 but knowing
this beast one or two more might pack up !
Thanks, Graham
F
Franc Zabkar
I suspect 4xUM means 4PDT, and SCHALTER-TAST means switch-tactile.
- Franc Zabkar
Eeyore
Franc said:
Eeyore put finger to keyboard and composed:
That sounds very likely indeed.
I'd imagined SCHALTER might be the brand but that puts a new light on
it. However browsing the ALPS website which I took to be the best bet, I
couldn't find any 4 pole switches of that style. Maybe I'll look again.
Many thanks anyway.
Graham
Eeyore
Soundhaspriority said:
"Eeyore" wrote
I have a bunch of finds, none of which may be relevant, but I pass them on
to you. The most interesting is
http://www.henri-electronic.de/start.php?P_989.php, which depicts a
bat-handle Schalter 4XUM.
Nope, none of those. That's when consoles had 'real' switches instead of using
consumer parts ! You'll find those on my first home-made desk.
Have a look at the below link. From what I gather, the actual brand is
"Schalter", which is owned by Assmann. "Tast" is German for "test", which I
suppose is actually a colloquial expression of a function, I don't know
what.
Page down. Besides the DIP switches, there is a type called a "taster."
http://www.bimel.com.tr/urun/pdf/assmann/elkcomp/08-assmann-wsw-ec-switches.pdf
Those are the small low profile tact(ile) switches. This one is much taller.
Also, google for "SCHALTER 4XUM"
No luck with that other than blind alleys.
From Franc's comments I'm thinking again it may be more likely to be an ALPS part
that I didn't see in the online catalogue. Midas do make a point of using ALPS
parts.
Graham
Boris Lau
what.
Schalter means switch. "Tast" is most probably an abbreviation for
"Taster", which is a switch that closes (or opens) the connection only
as long as you push it, rather than making the connection until you push
it again. What would be the English term for that kind of switch?
The German word for "test" is "test" as well.
Best from Germany ;-)
Boris
Eeyore
Momentary as opposed to latching.
But this is actually a latching switch. Maybe I selected the wrong part number.
Graham
Boris Lau
Let me know if you need more German assistance ;-)
Boris
Phil Allison
"Eeysore"
It's a nightmare
intermittently.
** Obviously YOU lack the necessary Midas touch !!!!!
Maybe just a little WD40 down the shaft will do the trick - not a whole
flood of it mind you.
Don't want that precious console to wind up looking like Venice.....
...... Phil ;-)
Jamie
Boris
Momentary ?
That is a switch you must hold and will release (off) when you left go.
http://webpages.charter.net/jamie_5"
F
Franc Zabkar
Indeed it is.
Graham
After some searching, it appears that the term "4xUM" is often
associated with relays.
I now believe that "UM" is an abbreviation for "umschaltung" which
translates to "changeover".
See http://www.dict.cc/german-english/Umschaltung.html
So 4xUM = 4PCO = 4PDT, ie you have a pushbutton switch with 4 pole
changeover contacts. But of course you already knew that from the
outset ... :)
BTW, my favourite switch lubricant/cleaner is Philips 390CCS.
- Franc Zabkar
Jamie
Phil said:
"Eeysore"
..... Phil ;-)
WD-40 (fish oil as main ingredient or used to be) dries out.
Spraying the contacts for suspected electrical issues, only
temporarily fixes, and normally makes it worse afterwards.
Since most chemicals tend to deteriorate the contact surfaces and
allows for pitted areas that no longer receives regular wiping from the
switch action, erosion sets in.
For proper restoration, switch contacts and surface ways need to
be polished and optionally copper antioxidant applied as used in
wire drawing operations.
Phil Allison
"Jamie" = Maynard A. Philbrook, KA1LPA
A radio ham & demented coder scribbler by trade.
Phil Allison:
** WD40 residue is ordinary light oil - whether it evaporates depends on
ambient temperature and local air flow.
At room temp and with no virtually no air flow, that takes years.
** The idea is to clean the surfaces and flush away contaminants.
Nothing to do with mysterious "electrical issues ".
** Light mineral oil is not a corrosive "chemical" - you fool.
and allows for pitted areas that no longer receives regular wiping from
the
** A coating of light oil protects the metal surfaces by excluding moisture
and air - you colossally stupid ASS .
Go away.
....... Phil
so sorry you posted this as PHIL will enter into his diatribe!!!
but you are correct in that wd 40 is not a lubricant!
water displacement formula 40.
Ross Herbert
:"Jamie" = Maynard A. Philbrook, KA1LPA
:A radio ham & demented coder scribbler by trade.
:> Phil Allison:
:>> ** Obviously YOU lack the necessary Midas touch !!!!!
:>> Maybe just a little WD40 down the shaft will do the trick - not a whole
:>> flood of it mind you.
:>> Don't want that precious console to wind up looking like Venice.....
:>> ..... Phil ;-)
:> WD-40 (fish oil as main ingredient or used to be) dries out.
:** WD40 residue is ordinary light oil - whether it evaporates depends on
:ambient temperature and local air flow.
WD40 MSDS
http://www.wd40.com.au/msds/ChemWatch MSDS WD-40_Aerosol.pdf
Certainly no fish oil in that lot. It is almost entirely petroleum based.
See http://palimpsest.stanford.edu/byform/mailing-lists/cdl/2005/1404.html
QUOTE
white spirit type 0;
CAS 64742 88 7, EC# 265 191 7.
Substance Name under ECB Annex 1 "Solvent naphtha (petroleum),
medium aliph. Straight run kerosine".
UNQUOTE
The secondary ingredient is a light petroleum based lubricating oil 64742-65-0.
http://msds.ergon.com/files/psmd-para/Hygold-P300N-MSDS.pdf
: At room temp and with no virtually no air flow, that takes years.
:> Spraying the contacts for suspected electrical issues, only
:> temporarily fixes, and normally makes it worse afterwards.
:** The idea is to clean the surfaces and flush away contaminants.
: Nothing to do with mysterious "electrical issues ".
:> Since most chemicals tend to deteriorate the contact surfaces
:** Light mineral oil is not a corrosive "chemical" - you fool.
:> and allows for pitted areas that no longer receives regular wiping from
:> the
:> switch action, erosion sets in.
:** A coating of light oil protects the metal surfaces by excluding moisture
:and air - you colossally stupid ASS .
: Go away.
:...... Phil
Eeyore
Which is why I won't be doing that.
Or fit a new switch !
Graham
Eeyore
That makes perfect sense.
outset ... :)
I think these 2 are way beyond that.
Graham
Jamie
Go away.
...... Phil
I can see your all talk and no experience pecker head!.. this just
proves it..
