Looking to Cross ref a Diac & Triac set
Tim
Hello again, I have a circuit for an electronic Variac that uses a Diac
and Triac to control the output. It looks like a glorified dimmer
circuit. Anyways it uses part # MAC2-4 for the triac and MPT-28 for the
trigger diode (diac). I haven't been able to cross reference these
puppies on the net. I hav checked the usual sources, but came up empty.
Any help would be appreciated.
- Tim -
H
Homer J Simpson
What load and operating voltage?
Generally a 10 amp triac and any 'normal' diac will do. This isn't precision
engineering.
Ray King
Tim,
The triac is not critical almost any will work but the diac is one that
triggers at 28 volts + or - 4 volts.
Ray
Eeyore
They're ancient, that'll be the problem !
Graham
Tim
Graham
Hmmm, this circuit was drawn in 2005, August 18th to be exact. It's
strange that the guy used old parts in the design. It also appears that
he has spec'd and drawn a triac, but the pins are marked cathode, anode
and gate, like an SCR. I think it should have MT1, MT2 and gate for a
triac.
The schematic is here;
http://homebrewradio.tripod.com/id58.html
- Tim -
Tim
engineering.
Yes, I figured I'd use the parts I have kicking around the shop, and I
thought mebbe someone would reconize the parts and tell me the ratings
on 'em.
The schematic is here if you are interested in the project;
Tim
Tim,
Ray
So is that what the -28 is for? Kinda makes sense. I am planning on
using some TO-220 15A triacs I have here. I'll be sure to get a 28v diac
tho.
The schematic is here if you are curious as to the application;
Thanks for the info,
- Tim -
Ray King
Tim,
Is this a diode on the ac input of of this circuit? Also is the load a
transformer? If either is true then the circuit will not work. You can not
control the primary of a transformer with a triac or two scr's at least over
the full range. you can go from zero to aproximately 75% depending on the
inductance vs the load and wheather or not the load is resistive or
rectified with a cap filter.
Ray
Tim
I had intended to use this as a variac to lower the operating voltage to
an RCA TV, to allow me to reset it's eeprom. The set uses a switching
power supply inside. It's a trick that some guru came up with to solve
the eeprom programming issue without a proper chip programmer.
Apparently these sets had a problem with this chip getting scrambled due
to bad grounds, bad soldering, and power flucuations.
I don't have access to a real variac, nor the funds to buy one, even if
one was available locally.
- Tim -
H
Homer J Simpson
over the full range. you can go from zero to aproximately 75%
You can with the right design. Fan controllers do it.
Ray King
Yes,
Fan motors are high slip and less inductive and more resistive. This similar
to a transformer with a full resistive load ( pure resistive). The fan motor
does not have as much mutual/leakage reactance that looks inductive to the
primary as the transformer with a pure resistive load.
Ray
F
Franc Zabkar
- Tim -
MPT-28 is a 28V diac:
http://www.nteinc.com/specs/6400to6499/pdf/nte6407.pdf
I don't see a MAC2-4 in either my 1984 Motorola catalogue or my NTE
1990-91 catalogue, but the "-4" appears to refer to a 200V device.
FWIW, the MAC20-4 is a 200V, 15A triac.
- Franc Zabkar
Ray King
There is a very good circuit for controlling the primary of any inductive
load. It consists of a switch in series with the ac input to the transformer
that pwm's the load. During the off time a second switch turns on in
parallel with the load. Each switch consists of fets or IGBT's either in
anti series or across the output ( + and - ) of a 4 diode bridge( fast
diodes ) . The fets/igbts are transformer driven ( both switches are driven
with the same transformer ) This will prevent the two switches from
conducting at the same time ( shoot through ). The output can be filtered so
the output looks like the output of a variac. The use of scr/triacs can not
be filtered very well and reek havoc with the switchers with cap input
filters.
Ray
Ray King
I have a 1979 mot catalog that does not list the MAC2-4 ----I have looked in
a 1981 D.A.T.A. BOOK with no results. The lowest numbers for the MAC is
MAC15-4.
Ray
Eeyore
Tim said:
[email protected] says...
It mnay simply be what he had in his box of bits !
triac.
It should.
They are non-critical as previously mentioned by others. Choose a triac to suit
your load. It's basically a triac based dimemr. Check any other similar designs
online for comparison.
Did you spot the deliberate mistake btw ?
Graham
Eeyore
That may not work very well actually.
Graham
Tim
It should.
Graham
Deliberate mistake? In the drawing? I can't see anything obvious...
- Tim -
ehsjr
Graham
I don't think it's a deliberate mistake. I suspect
it is just poor drawing of what is supposed to be
the output connector.
Ed
Tim
I got the TV set re-programmed without needing the variac thing. I
pulled the chip and re-programmed it in my eprom programmer using data
from a fellow tech on the net.
I did not need to build the circuit after all, but I appreciate
everyone's input on the project.
- Tim -
