Low cost USB spectrum analyzers for EMC?
Joerg
Hello All,
Just wondering. Since there is a plethora of nifty EE devices around
USB, is there a cheap USB spectum analyzer that runs from, say,
something like 150kHz to 1GHz? Something without a screen or anything fancy.
Google brought hits but they were either just audio or WLAN analyzers.
Considering the cost of WLAN cards for USB there ought to be something.
Regards, Joerg
fancy.
It sounds like you're after a complete product, but...
In the September and October 1989 issues of Radio-Electronics, there is
an article by Fred Baumgartner on a build-it-yourself spectrum analyzer.
Display is to an oscilloscope. The "hard part" is done by a Zenith TV
tuner module that converts 50-600 Mhz to 63 MHz (Channel 3) output. This
is followed by a TDA7000 FM receiver chip. There is a 555 to generate
the swept tuning voltage for the tuner and another oscillator for sync.
If you could get a USB D/A and A/D box, you could use the D/A side
(perhaps followed by an amp if the D/A is only 0-5V or similar) to
generate the tuning voltage and the A/D side to measure the signal
strength. With newer TVs and digital cable boxes, I would guess you
could find a tuner that would go up further than 600 Mhz. Finding one
that goes down below about 50 MHz might be a problem; perhaps you could
adapt a tuner made for shortwave radios.
Matt Roberds
mike
Joerg said:
Hello All,
fancy.
Regards, Joerg
Don't know what you mean by EMC, but if you intend testing for EMC
compliance, you might reconsider something hanging out of a PC.
You might find it radiates more than the thing you're testing.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
Joerg
Hello Mike,
It can be muffled. The PC itself can sit behind a screen. I even had to
do that with a professional $20k class EMC analyzer. It had a flat
screen and that radiated like crazy. So it wouldn't be a big deal.
Regards, Joerg
Joerg
Hello Matt,
Yes.
I have built something along these lines when I was young, to sweep a
ham band for activity. But that method is a lot of work and not very
accurate. Also it is limited to whatever the tuner can do and these
things are often lousy designs when it comes to dynamic range.
Considering all this cheap WLAN stuff there ought to be a USB analyzer
out there. Somewhere. Just the absence of a screen, power supply and
control knobs would drop the cost significantly.
Regards, Joerg
gabe
You could use your audio card to recieve the spectrum data
Pooh Bear
gabe said:
You could use your audio card to recieve the spectrum data?
Uh ! ? How does this relate to EMC ?
Graham
Rene Tschaggelar
Yes, partially at least. The EMC rules extend to 3GHz
and the audio card ends somewhat lower.
You could at least mix everything down into the audio
range.
Rene
Joerg
Hello Graham,
Good question :)
One scenario I could imagine though would be a controlled down-converter
and the sound card would take over as IF stage. SW would do the rest. It
won't be stellar in phase noise but for EMC work that rarely matters.
Regards, Joerg
