low power degaussing coil
Tim Worthington
I've got a small 5" colour monitor that I'm using a test monitor. It
came with a small degaussing coil but no associated electronics.
This monitor will be moved around a lot and I don't want to have to
degauss it with a degauss wand every time it gets a bit magnitised. So
i'm trying to think of a way to power the coil it already has.
I'm thinking about putting a posister, the coil and a degauss button
in series with the 240v mains available inside the box. What type of
posistor to use? I imagine most would let too much current through
before getting hot enough.
Philips seem to have a large selection (availabe as tv spares) but I
can't find specs anyware online...
The coil is 140mm in diameter and has a DC resistance of 8 ohms
any ideas?
Sam Goldwasser
any ideas?
Can't help with specs but all degaussing coils inside TVs and monitors
have a very low resistance and depend almost entirely on the Posistor
for current limiting to a safe value and of short duration.
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
Important: Anything sent to the email address in the message header above is
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
Phil Allison
"Tim Worthington"
degauss it with a degauss wand every time it gets a bit magnetised. So
** You need a bit more than that - usually a hefty relay is used to engage
the posistor circuit with a timer to hold it on for 5 seconds or so. The
button just initiates the timing cycle.
What type of
** De-gaussing coil current peaks at around 30 - 50 amps.
** Maybe just find an old PC monitor and remove one from it. But do not
just fit a simple on-off button or you will end up magnetising the tube very
badly.
............. Phil
Phil said:
"Tim Worthington"
I have Sanyo TVs built over 20 years ago that use nothing but a
posistor in series with the degaussing coil.
Phil Allison
button in series with the 240v mains available inside the box.
engage the posistor circuit with a timer to hold it on for 5 seconds or
so.
The button just initiates the timing cycle.
** TVs are nearly all like that.
However, the OP has a portable monitor that may need to be de-gaussed
whenever it is moved about.
Hence the need for a "de-gauss" button.
.............. Phil
