Low power (ultra) high voltage MOSFET
Ad Sprenkels
Hi All,
First post here...
Anyone knows if they even exist and where to get an N-channel Mosfet capable
of Vds>2000V at currents up to 1mA?
More detail: Vds>2000V, Vdg>2000V, Id < 1mA and VT 3-10V.
Thanks for any hint or comment,
Best regards,
Ad
MooseFET
Hi All,
First post here...
Best regards,
Ad
I don't thuink there are any they meet this. You may have to build
some sort of cascode circuit. Mosfets like the DN3145 from Supertex
would allow a few hundred volts per stage of the cascode. Depletion
mode devices have advanages in the later stages of a cascode. You can
make their gate voltages from the drain voltage of the last device.
This makes for good sharing of the power all the way down to ground.
Ad Sprenkels
Thanks for your comment!
I did indeed some experiments with two 1200V (enhancement) Mosfets in a
cascode like circuit, but has resulted in a rather complicated circuit.
I was wondering whether anyone on this forum would know about different
devices. It would simplify the circuit tremendously.
Thanks again,
Ad
D from BC
Thanks again,
Ad
[snip]
Maybe check out tube technology..
D from BC
Marte Schwarz
Hi Ad,
OK, not exact fit but may be ;-)
look to www.IXYS.com IXLF19N250A
OK it is built for 19 A but the rest may be OK :)
Marte
Ad Sprenkels
Hi Marte,
Thanks for the info!
I have spoken to the rep here in the Netherlands about these devices (IGBT)
but they accept only a minimum order of 24 pieces costing about $105 each.
This is beyond my budget....
Anyway, thanks very much and I will try to find another supplier with a more
appropriate offer.
Best Regards,
Ad
Phil Hobbs
Ad said:
Hi Marte,
appropriate offer.
Best Regards,
Ad
Sounds like a job for a tube. Last time I needed to do this sort of
thing I used an 811A--I really really needed low capacitance as
well--about 5 pF iirc. That was in about 1990, not 1960, btw. Tubes
are really amazing for that sort of job--they're not only for separating
fools from their money.
Cheers,
Phil Hobbs
Ad Sprenkels
Phil Hobbs said:
Sounds like a job for a tube. Last time I needed to do this sort of thing
I used an 811A--I really really needed low capacitance as well--about 5 pF
iirc. That was in about 1990, not 1960, btw. Tubes are really amazing
for that sort of job--they're not only for separating fools from their
money.
Cheers,
Phil Hobbs
Hi Phil,
Thanks for the advice.
I am really going to look for the tube solution, although I am not very
familiar with using tubes.
Perhaps a nice time to learn something new...
Thanks again,
Ad
Marte Schwarz
Hi Ad,
(IGBT) but they accept only a minimum order of 24 pieces costing about
$105 each.
Uff, few years ago I got samples for 20 EUR/piece. They told me that the
price in series production would be in this range, too. If you don't need
too much switching speed then you could use a series connection.
What's your goal? May be I can help more when I know what you want to do.
You may write me a mail. I'm not every day here, because there is too much
offtopic nowadays :-(
Marte
