[email protected]
- Jan 1, 1970
- 0
Would it be possible to use one of those universal AC/DC power supplies
as a 12-volt battery trickle charger?
The power supply is one of those that you can select the voltage via a
switch, you can choose between 3 - 4.5 - 6 - 7.5 - 9 or 12 volts.
The output is DC & the current of the supply is 300mA. (3.6VA max)
I ask as I have seen Motorcycle trickle battery chargers for sale,
these only put out 300mA & looking at these they look very similar to
the power supply I have with the exception that they can only be
switched between 6 & 12 volts.
Any advice appreciated.
