Measuring Peak Current with a Fluke 87 III
F
FunFred
Just recently I was using a Fluke 87 III to measure the peak current
in an AC circuit.
It was pointed out that I should be using the 1ms sampling range with
the Min/Max mode to catch it (it was on the default 100ms sampling).
OK, I didn't know it was available but you learn...
What confused me a little is that when you step through the readings
(max, min average) in 100ms mode I got a good 12A etc reading for max,
and a small negative value. I just ignored it as an irelivent
reading.
Once the 1ms mode is used I now seem to have a valid Max(positive)
reading and what apears to be a valid Min(Negative) reading.
I have looked in the manuls and googled etc, I'm still can not find a
statement as to what it means. Is it the Min reading in fact the max
negative current?
It would make sense to me.. it's just when you blow a fuse some times
the Min value is larger than the Max value (ignoring the sign).
So the question is, do I look at both the max and Min values, which
ever is largest it the real maximum current?
F
FunFred
Thanks Shaun.
Whilst the notes explain similar information to what's in the manual
with some history, it still does not say which is the highest reading
for example
meter is monitoring some AC current... an event occurs and the meter
has recorded the following
Max 2.86 Amps
Min -3.08 Amps
so in AC can you have -3.08 amps? (now i'm confused.)
I'm sort of assuming that these are the outputs from two a/d stages.
one for each polarity... every one says use the biggest but the manual
does not say anything.
I'm just concerned with the assumptions being made.
regards
Fred
Shaun
Well your right, it is kinda strange that the meter gives a negative number
on AC range for MIN in MIN / MAX mode. I have the exact same model of meter
you have but I haven't really played with that function.
I'd suggest you ask your question on the Fluke Community Forum, here is the
link:
http://www.flukecommunity.com/forums/index.php
At the top of the page is "register" - go to that first so that you can post
a question.
Shaun
F
FunFred
Hi Shaun et all
I've got on to the forums, looked through them and searched etc...
found some messages about min/max on resisitance and comparisons of
various meters etc..
I have asked for permission to post, but I'm still waiting..
I wish I had the time to do a comparison...
regards
Alan
