Measuring sound pressure level
Bubba
Greetings to all,
I was thinking about building low-cost analog sound level meter, however,
i am not sure how to get the non electrical value of sound pressure and
transform it in electrical value. I planned to display the level with
(cascaded) LM3915s', but was wandering about ideas of how to obtain sound
pressure level in the first place.
Thanks in advance!
steamer
--Howzabout using a speaker as the input device?
mike
Bubba said:
Greetings to all,
Thanks in advance!
Google is your friend.
You can get audio spectrum analyzer programs that run on your PDA to do
that function.
Plug a microphone into your sound card and download a free audio
spectrum analyzer program.
You don't say what test equipment you have, but using the sound card
and replacing one function in the chain at a time will get you there
in steps.
Your most difficult problem is the LARGE dynamic range that
the system has to handle. You'll end up with a bunch of range switches
that make the project 10X more complex...not difficult, just complex.
mike
Wanted, Serial cable for Dell Axim X5 PDA.
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
Bob Masta
Greetings to all,
This is a non-trivial problem. You need a calibrated microphone to do
this. Laboratory-grade "condenser" microphones which have stable
performance are very expensive ($1000) and require 200 VDC supplies
and special preamps. Instead, you can get a cheap microphone that
has a calibration curve. Panasonic electret capsules come to mind,
available from Digi-Key last time I looked. You will have to accept
that the calibration will be crude at best, and will not last
indefinitely. (Electrets lose sensitivity over time.)
Be sure to get an "omnidirectional" model, since the "unidirectional"
units generally have much poorer frequency response.
The calibration information will consist of a frequency response
curve (which for an omni electret will be pretty flat) plus a
sensitivity value. A typical listing is "-62 dB +/-3 dB (0 dB =
1V/ubar, at 1000 Hz)" For more information on how to
use this to go from volts to SPL, see "Some formulas
for working with sound" at
www.daqarta.com/uuccunit.htm#yy01
Also a general discussion of dB at:
www.daqarta.com/gg00glos.htm#gg0a
Hope this helps!
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Home of DaqGen, the FREEWARE signal generator
