Steve
- Jan 1, 1970
- 0
I want to make a metal enclosure for an electronics product. The enclosure
will be 4" wide, 6" long, 1" high. Up till now I've been using an
off-the-shelf standard extruded aluminum case. The main cost has been the
CNC milling of the front and rear panels (they both have a few holes for
connectors/buttons/LEDs). Plus it is a real pain to assemble, since the
front panel is glued to the sides in order to avoid screws showing through
(it's a consumer item). Now I am hopefully going to make them in bigger
batches (500s or so), I've been looking at other approaches to save money
and make assembly easier. So far, the alternatives I've thought about are:
a) Stay with the extruded aluminium and face plates, but use a stick-on
overlay over the front panel, so I can have screw holes in the panel behind
it. However, on such a small unit, I am worried that registration between
overlay and panel (and bubbles?) will make this problematic or at least be
slow during assembly - the less skill/judgement decisions required during
assembly, the better
b) Use a folded aluminium enclosure, one piece for base, front and rear, and
one piece for top and sides. Although this would get rid of the screws
needed to hold the box together, I still need some way of attaching a small
PCB with buttons and LEDs behind the front panel (I'm using foam and glue
for this at the moment!). I guess I could use blind fasteners for this, but
maybe that is not the best/cheapest solution.
c) A mod of (b) that seems to be used for DVD players etc. - folded aluminum
plus a plastic clip-on front panel to make it look nice. The metal panel
behind could then have all the screw holes etc. it needed. Not sure if the
cost of making the plastic panel is feasible for my quantities (500's)
Can anyone please suggest another approach, or comment on those above.
Many thanks,
Steve
Many thanks,
Steve
