mic and Impedance matching
larissam
Jan 15, 2015
I am working in a project, where i have a Microphone Electret with a impedance at the output of 2,2kohm. and a impedance matching (FET) where i am using Mosftet VQ1000J.
My target is to see at the output of the Transistor a sinusoidal signal from the microphone.
When i tried the circuit just the impedance matching with a signal generator at the input using
frequency 1khz, offset 1 volt and a peak to peak voltage amplitud 2 Volts. i got the signal i am looking for BUT when i connected directly to the microphone i dont get any signal at all.
I already tried the microphone alone and it works well.
I dont have to much knowledge about transistors and with audio circuits.
I know there are many things i am missing to make the connection between the microphone and the impedance matching work but i dont know which one should i look.
I dont know if the impedance from the microphone could be a reason why it doenst work.
any idea, i will be really grateful
thanks in advance
Larissa
Hi and welcome to the forum!
Typically, electret microphones have the JFET amplifier built in, and they need a power connection to work.
This article shows you how it is connected:
http://en.wikipedia.org/wiki/Electret_microphone
The output from the capacitor should provide a signal of about 5mV and go into a microphone preamplifier.
