Minolta RP603Z microfilm reader/printer help
Larry
Is there anyone who might have worked on a Minolta RP603Z microfilm
reader/printer over the years? I have a machine that is giving a
constant C2 error (High Voltage transformer malfunction error). This
problem used to occur very intermittently but has now become constant.
Any ideas?
No one anywhere near here knows how to fix this old machine and I would
like to get it going for the local Genealogy centre
TIA
Larry
H
Homer J Simpson
Does it work or not when it errors out?
I'm not familiar with the machine, but have had the same problem with
other machines (different error code number but the same error). The
most common cause if it is laser based would be the corona wire shorting
or arcing against metal. Certain models of Toshiba copiers have this
problem often.
Larry
C wrote:
: I'm not familiar with the machine, but have had the same problem with
: other machines (different error code number but the same error). The
: most common cause if it is laser based would be the corona wire
: shorting or arcing against metal. Certain models of Toshiba copiers
: have this problem often.
: Larry wrote:
: : Hello,
: : Is there anyone who might have worked on a Minolta RP603Z microfilm
: : reader/printer over the years? I have a machine that is giving a
: : constant C2 error (High Voltage transformer malfunction error).
: : This problem used to occur very intermittently but has now become
: : constant. Any ideas?
: : No one anywhere near here knows how to fix this old machine and I
: : would like to get it going for the local Genealogy centre
: : TIA
: : Larry
Thanks for that, I'll check it and make sure there isn't some
contamination etc in that area.
Larry
Larry
: : constant.
: Does it work or not when it errors out?
Hi Homer,
Error stops the machine instantly when it appears. Paper is part way
through when this happens but the error code is not paper related. On
this machine all error code stop the machine instantly.
Larry
: Larry wrote:
: : Hello,
: : TIA
: : Larry
Larry
The problem sounds exactly like what happens to Toshiba copiers. They
also stop working with the paper part way through. A quick fix is to
either shorten the corona wire or shorten tne tensioner spring. The
error code on them is C970
Clarence
