Mitsu CS-3505 problem
jpete
I have a Misubishi CS-3505 TV that I bought "used" from a "repair
shop" but after a return and no resolution to this problem, I hope I
can find an answer here. Plus, it's to heavy to take back AGAIN. :D
There are 2 problems that may or may not be related.
1) The vertical hold jumps so that the picture looks "letterboxed". It
will run this way indefinately, sometimes fixing itself. Usually, I
can turn the TV off until I hear a click, like a relay or something
and then turn it back on. This often works, but sometimes not.
2) The screen sometimes goes black but has a "rainbow" halo effect.
The best I can describe it is if you've ever pressed on an LCD like
on a calculator, you get an idea.
I only paid $175 for it so I don't want to put a ton of money into it
to have it fixed professionally. Is there someplace else I can look
for repair manuals? I have some skills, I'm a machinist/mechanic so I
can follow along pretty well. :wink:
Jeff
Jumpster Jiver
Jeff
These TVs are known for multiple bad electrolytic capacitors in multiple
circuits. Particularly many video problems can be traced to the same
cause but on the PIP board. Sometimes the caps are leaking and the acid
starts dissolving traces on the circuit board. If you have some kind of
warrant have it fixed or get your money back because this can become a
very long complex labor intensive repair. To get it fixed completely
and correctly may take hundreds of dollars worth of labor and many days
or weeks of repair time.
Get out of this while you can.
Wrong era tv set. This one is from around 1989 or so.
The CS3505 was pre-pip board problems and pre-mass capacitor problems.
However, given the age it is very possible that some capacitors are
failing, especially in the vertical deflection circuit.
It is pretty clear that the so-called repair shop did not do a complete
job in making sure the tv was going to work properly before selling it.
If they could not provide a resolution to the problem, seems to me the
entire money should be refunded or they should come out and fix it on
site.
site.
James Sweet
Or just bypass the PiP board, it's what I do when the damage is too severe,
not many people use that feature, half those I've repaired didn't know they
had PiP in the first place.
Similar threads
N
Replies
7
2K
Leonard Caillouet
Replies
3
1K
Leonard Caillouet
Replies
1K
Leonard Caillouet
