Mitsubishi Big screen Ws-65819 won't turn on
showtime
Green power light comes for a couple of seconds then goes off, Tv
clicks but no picture or sound. I replaced blown fuses F9A04 & F9A05.
Tv is about 2 years old. Any Suggestions?
Mark
Jerry G.
Most likely there is a failure in the power supply itself, or in the
horiz scan amplifier, or high voltage section. A failure in the
vertical amplifier can also cause an overload back to the powersupply
as well, depending on the nature of the failure.
I would suggest you call a service center to have your set serviced.
Jerry G.
Similar threads
Replies
4
2K
Leonard Caillouet
Replies
5
2K
Leonard Caillouet
Replies
4
2K
Leonard Caillouet
