Hello
I worked in a place that gave me access to budget, non memory 20MHz CRT
scopes - I no longer work there. They were perfect for my needs.
Six years on and I find I need an oscilloscope, the market seems to have
changed. Are those cheap digital models any good?
I need reasonable Y sensitivity (5mV/div), up to 5MHz, storage would be
nice, it's not for radio work.
<Shameless plug>
How about a cheap analog scope, supplemented by a
ridiculously-cheap (US$29) Windows sound card scope for
audio work?
Sound cards don't do DC (without mods or external help), but
the "audio" range keeps creeping up... these days you can
get to nearly 96 kHz (192 kHz sample rates) even on cheap
built-in sound chipsets.
With the proper software (hint, hint!) you can get fancy
triggering, including negative trigger delay, hysteresis,
hold-off, etc. You can get real-time FFT spectrum analysis
(with optional peak tracking), and color spectrograms.
Synchronous waveform averaging allows stupendous noise
reduction... you can easily extract signals that were
totally buried in noise. See for example:
http://www.daqarta.com/dw_wavg.htm>
Best of all, you get a signal generator that can create
almost any signal you want, with modulation including AM,
FM, PM, Burst, and Sweep on up to 4 independent streams per
stereo output channel. It can drive all your tests, and
provide the sync for the averaging as well. See:
http://www.daqarta.com/dw_gen,htm>
(Actually, the generator is free. Even if you stick with
only an analog scope, or a cheap DSO, you will find plenty
of uses for the signal generator.)
Lots of other features, like a frequency counter that can
read low frequencies quickly with high precision (due to
reciprocal period methods). True RMS measurements. Sound
level (SPL) meter (if you have a calibrated microphone).
Histograms, including post-stimulus time histograms.
The $99 Pro version allows you to write macros to run
automated test sequences, allows custom spectrum response
limits for pass/fail production testing, and supports remote
control from custom software.
Best regards,
Bob Masta
DAQARTA v6.02
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Scope, Spectrum, Spectrogram, Sound Level Meter
Frequency Counter, FREE Signal Generator
Pitch Track, Pitch-to-MIDI
Science with your sound card!
